Datasheet HMC705LP4, HMC705LP4E (Analog Devices) - 7
Description6.5 GHz Programmable Divider (N = 1 - 17)
Pages / Page12 / 7 — HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Pin …
HMC705LP4 / HMC705LP4E. 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17). Pin Description
HMC705LP4 / HMC705LP4E 6.5 GHz PROGRAMMABLE DIVIDER (N = 1 - 17) Pin Description
v04.0212
Pin number Function Description interface schematic t the pins are not connected internally; however, all data M 1 - 6, 8, 18 n/c shown herein was measured with these pins connected to s rF/Dc ground externally. s - r PFD invert function o Div1, s0 cMos compatible input control bit t 7, 20 - 24 n0 - n2 c ByP Logic “LoW” = norMAL e Logic “HiGH” = invert t e s & D 9, 19 vcc1, vcc2 supply voltage r e iD 10, 13, 14, these pins and package bottom GnD 17 must be connected to rF Dc ground. iv 11 nFin (these pins are Ac coupled and must be Dc Blocked externally.) y D Frequency input c n 12 Fin Frequency input complement e u q 15 nFout Frequency, output complement e r F 16 Fout Frequency output I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
