Datasheet HMC433, 433E (Analog Devices) - 3
DescriptionSMT 4 SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 8 GHz
Pages / Page6 / 3 — HMC433 / 433E. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 8 GHz. Output Voltage …
File Format / SizePDF / 356 Kb
HMC433 / 433E. SMT GaAs HBT MMIC. DIVIDE-BY-4, DC - 8 GHz. Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC433 / 433E SMT GaAs HBT MMIC DIVIDE-BY-4, DC - 8 GHz Output Voltage Waveform, Pin= 0 dBm, Fout= 882 MHz, T= 25 °C
HMC433 / 433E
v04.0410
4 300 200 T 100 0 -100 AMPLITUDE (mV) S - SM -200 R -300 O 23 23.4 23.8 24.2 24.6 25 T TIME (nS) C E T E
Absolute Maximum Ratings Reliability Information
RF Input Power (Vcc = +3V) 15 dBm Junction Temperature to Maintain 135 °C 1 Million Hour MTTF & D Nominal +3V Supply to GND -0.3V to +3.5V Nominal Junction Temperature S Max Peak Flow Temperature 260 °C 99 °C (T = 85 °C) R Storage Temperature -65 to +125 °C Thermal Resistance E 83 °C/W (Junction to GND Paddle, 3V Supply) ID Operating Temperature -40 to +85 °C IV Y D
Typical Supply Current vs. Vcc
DC blocking capacitors are required at RF input and RF output ports. Vcc (V) Icc (mA) NC Choose value for lowest frequency of operation. 2.70 42 E 3.0 53 U ELECTROSTATIC SENSITIVE DEVICE 3.30 63 Q Note: Divider will operate over full voltage range shown above OBSERVE HANDLING PRECAUTIONS E R F Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
4 - 74
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
