Datasheet LTC6410-6 (Analog Devices) - 2
DescriptionLow Distortion, Low Noise Differential IF Amplifier with Configurable Input Impedance
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 359 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC6410-6
Total Supply Voltage (V+ to V–) ..5.5V TOP VIEW Amplifi er Input Current (DC) +TERM +IN –IN –TERM (+IN, –IN, +TERM, –TERM) ...±10mA 16 15 14 13 Amplifi er Input Power (AC) V– 1 12 V– (+IN, –IN, +TERM, –TERM) ...18dBm V 2 11 BIAS SHDN 17 Input Current (V V+ 3 10 V+ BIAS, SHDN) ..±10mA Output Current (+OUT, –OUT) ..±50mA V– 4 9 V– 5 6 7 8 Operating Temperature Range (Note 2).. –40°C to 85°C + + V V Specifi ed Temperature Range (Note 3) .. –40°C to 85°C +OUT –OUT Storage Temperature Range ... –65°C to 150°C UD PACKAGE 16-LEAD (3mm × 3mm) PLASTIC QFN Junction Temperature .. 150°C TJMAX = 150°C, θJA = 68°C/W, θJC = 4.2°C/W Lead Temperature (Soldering, 10 sec) .. 300°C EXPOSED PAD (PIN 17) IS V–, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE (Notes 2, 3)
LTC6410CUD-6#PBF LTC6410CUD-6#TRPBF LDBG 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LTC6410IUD-6#PBF LTC6410IUD-6#TRPBF LDBG 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
The 3V DC ELECTRICAL CHARACTERISTICS
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, SHDN = 2V, +IN is shorted to +TERM, –IN is shorted to –TERM, VBIAS = 1.5V, +IN = –IN = 1.5V, input source resistance (RS) is 25
Ω
on each input (50
Ω
differential), RL = 50
Ω
from +OUT to –OUT, unless otherwise noted. VBIAS is defi ned as the voltage on the VBIAS pin. VOUTCM is defi ned as (+OUT + –OUT)/2. VINCM is defi ned as (+IN + –IN)/2. VINDIFF is defi ned as (+IN – –IN). VOUTDIFF is defi ned as (+OUT – –OUT). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
GDIFF Differential Gain VINDIFF = ±0.2V 5.0 6.0 6.7 dB (Low Frequency S21) l 4.7 7.0 dB TC GDIFF Differential Gain Temperature l 0.003 dB/°C Coeffi cient VSWINGDIFF Differential Output Voltage Swing VOUTDIFF, VINDIFF = ±2V 2.2 2.8 VP-P l 2.0 VP-P VSWINGMIN Output Swing Low Single-Ended +OUT, –OUT, VINDIFF = ±2V 0.7 0.9 V l 1.0 V VSWINGMAX Output Swing High Single-Ended +OUT, –OUT, VINDIFF = ±2V 1.9 2.1 V l 1.8 V IOUT Output Current Drive Short +OUT to –OUT, VINDIFF = ±2V (Note 4) ±38 ±42 mA l ±36 mA VOS Input Offset Voltage –2.0 0.4 2.0 mV l –3.0 3.0 mV 64106fa 2
