Datasheet LT1007, LT1037 (Analog Devices) - 16
DescriptionLow Noise, High Speed Precision Operational Amplifiers
Pages / Page16 / 16 — TYPICAL APPLICATIO. Strain Gauge Signal Conditioner with Bridge …
File Format / SizePDF / 532 Kb
TYPICAL APPLICATIO. Strain Gauge Signal Conditioner with Bridge Excitation. RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS
TYPICAL APPLICATIO Strain Gauge Signal Conditioner with Bridge Excitation RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1007/LT1037
U TYPICAL APPLICATIO Strain Gauge Signal Conditioner with Bridge Excitation
7.5V 5k 2.5V 3 7 + 6 LT1007 LT1009 2 – 4 –7.5V REFERENCE OUT 350Ω 15V BRIDGE 3 + 7 6 OUTPUT LT1007 301k* 0V TO 10V ZERO 2 – TRIM 4 1µF 301k* 10k 7.5V –15V GAIN 2 – 7 TRIM 499Ω* 6 50k LT1007 *RN60C FILM RESISTOR 3 + THE LT1007 IS CAPABLE OF PROVIDING EXCITATION CURRENT 4 DIRECTLY TO BIAS THE 350Ω BRIDGE AT 5V. WITH ONLY 5V ACROSS THE BRIDGE (AS OPPOSED TO THE USUAL 10V) TOTAL POWER –7.5V DISSIPATION AND BRIDGE WARM-UP DRIFT IS REDUCED. THE BRIDGE OUTPUT SIGNAL IS HALVED, BUT THE LT1007 CAN AMPLIFY THE REDUCED SIGNAL ACCURATELY. 1007/37 TA09
LT1028 Ultralow Noise Precision Op Amp Lowest Noise 0.85nV/√Hz LT1115 Ultralow Noise, Low distortion Audio Op Amp 0.002% THD, Max Noise 1.2mV/√Hz LT1124/LT1125 Dual/Quad Low Noise, High Speed Precision Op Amps Similar to LT1007 LT1126/LT1127 Dual/Quad Decompensated Low Noise, High Speed Precision Op Amps Similar to LT1037 LT1498/LT1499 10MHz, 5V/µs, Dual/Quad Rail-to-Rail Input and Output Precision C-LoadTM Op Amps C-Load is a trademark of Linear Technology Corporation. sn100737 100737fbs LT/CPI 1101 1.5K REV B • PRINTED IN USA 16 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 1985
