Datasheet MAX4322, MAX432, MAX4326, MAX4327, MAX4329 (Maxim) - 2
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps
Pages / Page17 / 2 — Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op …
Revision3
File Format / SizePDF / 510 Kb
Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps. ABSOLUTE MAXIMUM RATINGS
Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps ABSOLUTE MAXIMUM RATINGS
Supply Voltage (VCC - VEE) ...7.5V 8-Pin µMAX (derate 4.10mW/°C above +70°C) ...330mW All Other Pins ...(VCC + 0.3V) to (VEE - 0.3V) 10-Pin µMAX (derate 5.6mW/°C above +70°C) ...444mW Output Short-Circuit Duration...Continuous 14-Pin SO (derate 8.00mW/°C above +70°C)..640mW (Short to Either Supply) Operating Temperature Range Continuous Power Dissipation (TA = +70°C) MAX432_E__ ...-40°C to +85°C 5-Pin SOT23 (derate 7.1mW/°C above +70°C)..571mW Maximum Junction Temperature ...+150°C 6-Bump UCSP (derate 3.9mW/°C above +70°C)...308mW Storage Temperature Range ...-65°C to +160°C 6-Pin SOT23 (derate 7.1mW/°C Above + 70°C) ..571mW Bump Reflow Temperature ..+235°C 8-Pin SO (derate 5.88mW/°C above +70°C)..471mW Lead Temperature (soldering, 10s) ...+300°C Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
DC ELECTRICAL CHARACTERISTICS—TA = +25°C
(VCC = 5.0V, VEE = 0V, VCM = 0V, VOUT = VCC/2, SHDN = VCC, RL connected to VCC/2, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX432_ESA/ ±0.7 ±2.0 Input Offset Voltage V MAX4327ESD OS VCM = VEE or VCC mV All other packages ±1.2 ±2.50 Input Bias Current IB VCM = VEE or VCC ±50 ±150 nA Input Offset Current IOS VCM = VEE or VCC ±1 ±12 nA Differential Input Resistance RIN -1.5V < VDIFF < +1.5V 500 kΩ Common-Mode Input Voltage CMVR Inferred from CMRR test VEE VCC V Range MAX432_ESA/ 62 94 MAX4327ESD Common-Mode Rejection Ratio CMRR VEE ≤ VCM ≤ VCC dB All other packages 60 91 Power-Supply Rejection Ratio PSRR VCC = 2.4V to 6.5V 66 100 dB Output Resistance ROUT AV = +1V/V 0.1 Ω VOUT = 0.25V to 4.75V, RL = 100kΩ 106 Large-Signal Voltage Gain AV dB VOUT = 0.4V to 4.6V, RL = 250Ω 70 86 VCC - VOH 12 RL = 100kΩ MAX4322/ VOL - VEE 20 MAX4323 VCC - VOH 200 300 RL = 250Ω VOL - VEE 100 200 Output Voltage Swing VO mV VCC - VOH 15 R MAX4326/ L = 100kΩ VOL - VEE 25 MAX4327/ VCC - VOH 220 350 MAX4329
MAX4322/MAX4323/MAX4326/MAX4327/MAX4329
RL = 250Ω VOL - VEE 120 250 Output Short-Circuit Current ISC 50 mA VIL Low 0.8 SHDN Logic Threshold MAX4323/MAX4327 V VIH High 2.0 SHDN Input Current MAX4323/MAX4327 ±1 ±4 µA
2 _______________________________________________________________________________________
