Datasheet HMC740ST89E (Analog Devices) - 5
DescriptionInGaP HBT Active Bias MMIC Amplifier, 0.05 - 3 GHz
Pages / Page8 / 5 — HMC740ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Output …
File Format / SizePDF / 675 Kb
HMC740ST89E. InGaP HBT ACTIVE BIAS. MMIC AMPLIFIER, 0.05 – 3 GHz. Output IP3 vs. Vcc. Current vs. Temperature
HMC740ST89E InGaP HBT ACTIVE BIAS MMIC AMPLIFIER, 0.05 – 3 GHz Output IP3 vs Vcc Current vs Temperature
HMC740ST89E
v02.0813
8
Output IP3 vs. Vcc Current vs. Temperature
50 140 40 120 +25C +85C T -40C ) M 30 (mA) 100 (dBm IP3 20 4.5V 5.0V 80 5.5V CURRENT K - S 10 60 C 0 40 LO 0 0.5 1 1.5 2 2.5 3 4.5 4.75 5 5.25 5.5 FREQUENCY (GHz) VOLTAGE (V) IN B A
P1dB vs. Temperature Psat vs. Temperature
20 20 R & G 15 15 E IV (dBm) +25C (dBm) +25C R 10 10 +85C +85C -40C -40C P1dB Psat 5 5 S - D R 0 0 0 0.5 1 1.5 2 2.5 3 0 0.5 1 1.5 2 2.5 3 IE FREQUENCY (GHz) FREQUENCY (GHz) LIF P M
Power Compression @ 500 MHz Power Compression @ 2 GHz
A 20 20 (%) 15 (%) 15 PAE PAE 10 10 (dB), (dB), 5 5 GAIN GAIN 0 0 (dBm), (dBm), -5 Pout -5 Pout Gain Gain Pout Pout PAE PAE -10 -10 -20 -17 -14 -11 -8 -5 -2 1 4 7 -20 -16 -12 -8 -4 0 4 8 INPUT POWER (dBm) INPUT POWER (dBm) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e Anry a alog n D d t evic o p es is la be clie o eved rd to e b r e sa: H ccur iattte itae M nd reliic a r bl o e w . H a o v wee C ver, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
8 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
