Datasheet VERSA-PAC (Eaton) - 4
ManufacturerEaton
DescriptionInductors and Transformers (Surface Mount)
Pages / Page9 / 4 — Dimensions- mm. NOTES:. max. ref
Dimensions- mm NOTES: max ref
VP Technical Data 4301 VERSA-PAC® Inductors and Transformers (Surface Mount) Effective August 2017
Dimensions- mm
VP2 and VPH2 TOP VIEW RECOMMENDED PCB LAYOUT WHITE DOT N PIN #1 LOGO (OPTIONAL) 1 12 M P D VPH 1 12 (10PLCS) (12 PLCS) _- A K _ _ COMPONENT
NOTES:
_ J (12PLCS) _ 0 SIDE (10PLCS) 6 7 1)Tolerances A - I are ± 0.25 mm unless specified 6 7 otherwise. B L 2)Tolerances J - P are +/- 0.1 mm unless specified (12PLCS) otherwise. C 4 3)Marking: 10 a)Dot for pin #1 identification b) VP(H)x-xxx (product code, size, 4 digit part FRONT VIEW number per family table.) 1 7 c) Versa Pac Logo (optional) E 5 11 d) wwl yy = (date code) R = (revision level) 4)Al soldering surfaces must be coplanar within 0.102 mm. 2 8 5)Packaged in tape and reel 300 parts per reel F 6 12 I G H (12 PLCS) (2 PLCS) 3 9 WWLLYY R 1:1:1:1:1:1
A B C D E F G H I J K L M N O P mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm max ref max ref ref max ref ref ref ref ref max
VP2 and VPH2 16.3 12.0 16.8 0.7 6.7 7.8 2.0 0.1 0.30 14.25 1.75 2.5 13.0 18.0 2.5 0.75 VP3 and VPH3 M L TOP VIEW O WHITE DOT (10PLCS) PIN #1 1 12 J 1 12 COMPONENT I (12PLCS) N D SIDE VPH_-_ _ _ _ (10PLCS) (12 PLCS) LOGO A 6 7 (OPTIONAL) K (12PLCS)
NOTES:
6 7 1) Tolerances A - I are ± 0.25 mm unless specified 1 4 otherwise. B 2) Tolerances J - P are +/- 0.1 mm unless specified C otherwise. 3) Marking: 12 9 a) Dot for pin #1 identification 2 5 b) VP(H)x-xxx (product code, size, 4 digit part FRONT VIEW number per family table.) c) Versa Pac Logo (optional) 11 8 d) wwl yy = (date code) R = (revision level) 4) Al soldering surfaces must be coplanar within E 3 6 0.102 mm. 5) Packaged in tape and reel 200 parts per reel H G (12 PLCS) F (2 PLCS) (12 PLCS) 10 7 1:1:1:1:1:1
A B C D E F G H I J K L M N O mm mm mm mm mm mm mm mm mm mm mm mm mm mm mm max ref max ref max ref ref ref ref ref max
VP3 and VPH3 17.1 16.0 22.3 0.7 8.4 3.0 0.1 0.4 14.49 1.79 3.43 16.88 23.74 2.54 0.75 4 www.eaton.com/electronics
