Datasheet HMC6187LP4E (Analog Devices)
DescriptionVariable Gain Amplifier SMT, 27 - 31.5 GHz
Pages / Page8 / 1 — HMC6187LP4E. VARIABLE GAIN AMPLIFIER. 27 - 31.5 GHz. Typical …
HMC6187LP4E. VARIABLE GAIN AMPLIFIER. 27 - 31.5 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC6187LP4E Analog Devices
HMC6187LP4E
v00.0312
VARIABLE GAIN AMPLIFIER 27 - 31.5 GHz Typical Applications Features
The HmC6187lp4e is ideal for: Wide Gain Control range: 13 db T • Point-to-Point Radio Single Control Voltage m • Point-to-Multi-Point Radio Output ip3 @ max Gain: +31 dbm • EW & ECM Subsystems Output p1db: +24 dbm • Ka-Band Radar & VSAT r - S no external matching • Test Equipment ie 24 lead 4x4 mm SmT package: 16 mm2
Functional Diagram
lif
General Description
p The HmC6187lp4e is a Gaas mmiC pHemT analog m variable gain amplifier and/or driver amplifier which a operates between 27 and 31.5 GHz and is ideal for in microwave radio applications. The amplifier provides a up to 19 db of gain, output p1db of up to +24 dbm, and up to +31 dbm of output ip3 at maximum gain, while requiring 230 ma from a +5V supply. a gain control voltage (Vctrl) is provided to al ow variable le G b gain control up to 13 db. Gain flatness is excel ent making the HmC6187lp4e ideal for eW, eCm and ia radar applications. The HmC6187lp4e is housed in r a roHS compliant 4 x 4 mm plastic Qfn leadless a V package and is compatible with high volume surface mount manufacturing.
Electrical Specifications, T = +25°C, Vdd1, 2, 3, 4 = 5V, Vctrl= -4.5V, Idd = 230 mA[1] A
parameter min. Typ. max. Units frequency range 27 - 31.5 GHz Gain
[2]
16 19 db Gain flatness ±0.5 db Gain Variation Over Temperature 0.02 db/ °C Gain Control range 13 db noise figure
[2]
4.5 db input return loss 12 db Output return loss 15 db Output power for 1 db Compression (p1db)
[2]
21 24 dbm Saturated Output power (psat)
[2]
25 dbm Output Third Order intercept (ip3)
[2]
31 dbm Total Supply Current (idd) 230 ma
[1]
Set Vctrl = -4.5V and then adjust Vgg1, 2 between -2V to 0V to achieve idd = 230 ma typical.
[2]
board loss subtracted out. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
