Datasheet HMC6187LP4E (Analog Devices) - 3
DescriptionVariable Gain Amplifier SMT, 27 - 31.5 GHz
Pages / Page8 / 3 — HMC6187LP4E. VARIABLE GAIN AMPLIFIER. 27 - 31.5 GHz. Input Return Loss @. …
HMC6187LP4E. VARIABLE GAIN AMPLIFIER. 27 - 31.5 GHz. Input Return Loss @. Output Return Loss @. Control Voltage Extreme
HMC6187LP4E VARIABLE GAIN AMPLIFIER 27 - 31.5 GHz Input Return Loss @ Output Return Loss @ Control Voltage Extreme
HMC6187LP4E
v00.0312
VARIABLE GAIN AMPLIFIER 27 - 31.5 GHz Input Return Loss @ Output Return Loss @ Control Voltage Extreme Control Voltage Extreme
0 0 T -4.5V -5 -5 -4.5V m -1.0V -1.0V -10 (dB) -10 (dB) -15 LOSS -15 LOSS r - S -20 ie -20 RETURN RETURN -25 -25 -30 lif p -30 -35 27 28 29 30 31 32 27 28 29 30 31 32 m FREQUENCY (GHz) FREQUENCY (GHz) a in a
Noise Figure vs. Temperature Noise Figure vs. Control Voltage
10 18 16 +25C le G 8 +85C ) -40C 14 ) 27 GHz b 28 GHz (dB (dB 12 E 29.5 GHz 6 E ia R R 30.5 GHz U U 10 IG 31.5GHz IG r F F 8 E 4 E a IS IS O 6 O V N N 2 4 2 0 0 27 28 29 30 31 32 -4.5 -4 -3.5 -3 -2.5 -2 -1.5 -1 FREQUENCY (GHz) CONTROL VOLTAGE (V)
P1dB vs. Temperature, Vctrl= -4.5V Psat vs. Temperature, Vctrl=-4.5V
30 30 25 25 20 20 (dBm) +25 C 15 (dBm) 15 +85 C +25 C -40 C +85 C P1dB Psat 10 -40 C 10 5 5 0 0 27 28 29 30 31 32 27 28 29 30 31 32 FREQUENCY (GHz) FREQUENCY (GHz) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
