Datasheet IS2083 (Microchip) - 8
Manufacturer | Microchip |
Description | Bluetooth Stereo Audio SoC |
Pages / Page | 65 / 8 — IS2083. Quick References. ...continued. Acronyms/Abbreviations. … |
File Format / Size | PDF / 2.9 Mb |
IS2083. Quick References. ...continued. Acronyms/Abbreviations. Description. Datasheet
IS2083 Quick References ...continued Acronyms/Abbreviations Description
MSPK Multi-speaker NR Noise Reduction OTA Over-the-Air PBAP Phone Book Access Profile PCB Printed Circuit Board PCM Pulse Code Modulation PDM Pulse Density Modulation PIM Plug-in Module PLC Packet Loss Concealment PMU Power Management Unit POR Power-on Reset PWM Pulse Width Modulation RF Radio Frequency RFS Receive Frame Sync RoHS Restriction of Hazardous Substances RSSI Received Signal Strength Indicator RX Receiver SAR Successive Approximation Register SBC Sub-band Coding SCO Synchronous Connection-oriented SDK Software Development Kit SIG Special Interest Group SNR Signal-to-Noise Ratio SoC System-on-Chip SPP Serial Port Profile SW Software TX Transmitter UART Universal Asynchronous Receiver-Transmitter UI User Interface USB Universal Serial Bus VB Virtual Bass Enhancement VCO Voltage-controlled Oscillator WDT Watchdog Timer © 2019 Microchip Technology Inc.
Datasheet
DS70005403B-page 8 Document Outline Introduction Features Table of Contents 1. Quick References 1.1. Reference Documentation 1.2. Acronyms/Abbreviations 2. Device Overview 2.1. IS2083BM Device Ball Diagram 2.2. IS2083BM Device Ball Description 3. Audio Subsystem 3.1. Digital Signal Processor 3.2. Codec 3.2.1. Audio Performance 3.3. Auxiliary Port 3.4. Microphone Inputs 3.5. Analog Speaker Output 4. Bluetooth Transceiver 4.1. Transmitter 4.2. Receiver 4.3. Synthesizer 4.4. Modulator-Demodulator 4.5. Adaptive Frequency Hopping 5. Microcontroller 5.1. Memory 5.2. Clock 6. Power Management Unit 6.1. Device Operation 6.2. Power Supply 6.3. Adapter Input 6.4. Buck1 (BK1) Switching Regulator 6.5. Buck2 (BK2) Switching Regulator 6.6. Low-Droput Regulator 6.7. Battery Charging 6.7.1. Battery Charger Detection 6.8. SAR ADC 6.9. LED Driver 7. Application Information 7.1. Power On/Off Sequence 7.2. Reset 7.3. Programming and Debugging 7.3.1. Test Mode 7.3.2. Flash Memory and SQI Controller 7.3.2.1. SQI Controller 7.3.3. 2-wire Interface 7.3.3.1. Serial Program Clock 7.3.3.2. Serial Program Data 7.3.4. Enabling Programming Interface 7.3.5. On-chip Instrumentation 7.3.5.1. Enabling OCI Functionality 7.3.5.2. Entering Debug Mode 7.3.5.3. Reading the Debug Status 7.3.5.4. Reading the Program Counter 7.3.5.5. Stopping Program Execution (Entering Debug Mode) 7.3.5.6. Starting Program Execution (Exiting Debug Mode) 7.3.5.7. User Single Step Mode 7.3.5.8. OCI Single Step Mode 7.3.5.9. Setting Software Breakpoints 7.3.5.10. Simple and Complex Debug Triggers 7.3.5.11. Reading and Writing Memory/SFR Registers 7.3.5.12. Trace Buffer 7.3.5.13. Instruction Trace 7.4. General Purpose I/O Pins 7.5. I2S Mode Application 7.6. Host MCU Interface 8. Electrical Specifications 8.1. Timing Specifications 9. Package Information 10. Ordering Information 11. Document Revision History The Microchip Website Product Change Notification Service Customer Support Microchip Devices Code Protection Feature Legal Notice Trademarks Quality Management System Worldwide Sales and Service
