Datasheet ADT7517-KGD (Analog Devices) - 7
DescriptionSPI-/I2C-Compatible, Temperature Sensor, 4-Channel ADC and Quad Voltage Output
Pages / Page11 / 7 — Known Good Die. ADT7517-KGD. TIMING DIAGRAMS. SCL. SDA. DATA IN. DATA …
File Format / SizePDF / 243 Kb
Known Good Die. ADT7517-KGD. TIMING DIAGRAMS. SCL. SDA. DATA IN. DATA OUT. SCLK. DIN. DOUT. 200µA. IOL. TO OUTPUT. 1.6V. PIN. 50pF. IOH. VDD. 4.7kΩ. TO DAC
Known Good Die ADT7517-KGD TIMING DIAGRAMS SCL SDA DATA IN DATA OUT SCLK DIN DOUT 200µA IOL TO OUTPUT 1.6V PIN 50pF IOH VDD 4.7kΩ TO DAC
Known Good Die ADT7517-KGD TIMING DIAGRAMS t1 SCL t t t 2 5 4 SDA DATA IN t3 SDA DATA OUT t6
002
t7
10686- Figure 2. I2C Bus Timing Diagram
CS t1 t2 t7 SCLK t t 3 t 6 5 DIN D7 D6 D5 D4 D3 D2 D1 D0 X X X X X X X X t4 t8
003
DOUT X X X X X X X X D7 D6 D5 D4 D3 D2 D1 D0
10686- Figure 3. SPI Bus Timing Diagram
200µA IOL TO OUTPUT 1.6V PIN CL 50pF
004
200µA IOH
10686- Figure 4. Load Circuit for Access Time and Bus Relinquish Time
VDD 4.7kΩ TO DAC OUTPUT 4.7kΩ
005
200pF
10686- Figure 5. Load Circuit for DAC Outputs Rev. A | Page 7 of 11 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DAC AC CHARACTERISTICS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
