Datasheet HMC862A (Analog Devices)
Description | 0.1 GHz to 24 GHz, Low Noise, Programmable Divider |
Pages / Page | 15 / 1 — 0.1 GHz to 24 GHz, Low Noise,. Programmable Divider. Data Sheet. HMC862A. … |
Revision | A |
File Format / Size | PDF / 483 Kb |
0.1 GHz to 24 GHz, Low Noise,. Programmable Divider. Data Sheet. HMC862A. FEATURES. FUNCTIONAL BLOCK DIAGRAM
0.1 GHz to 24 GHz, Low Noise, Programmable Divider Data Sheet HMC862A FEATURES FUNCTIONAL BLOCK DIAGRAM Low noise floor: −153 dBc/Hz at 100 kHz offset HMC862A D D Programmable frequency divider (N) CC CC V GN GN V N = 1, 2, 4, or 8 61 51 41 31 Wide bandwidth: 0.1 GHz to 24 GHz Low current consumption: 81 mA in the N = 8 divide state GND 1 12 GND HBM ESD sensitivity, Class 2 classification IN 2 11 OUT FICDM ESD sensitivity, Class C3 classification ÷1,2,4,8 16-lead, 3 mm × 3 mm LFCSP package: 9 mm2 IN 3 10 OUT GND 4 9 GND APPLICATIONS Satellite communication systems 5 6 7 8 PACKAGE BASE Point to point and point to multipoint radios
001
S0 S1 S2 D GND Military applications GN
13599- Figure 1.
Test equipment GENERAL DESCRIPTION
The HMC862A is a low noise, programmable frequency divider The low phase noise, wide frequency range, and flexible division in a 3 mm × 3 mm, leadless, surface-mount package. The ratio make this device ideal for high performance and wideband frequency divider, N, can be programmed to divide from 1, communication systems. 2, 4, or 8 in the 0.1 GHz to 24 GHz input frequency range.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
