Datasheet HMC862A (Analog Devices) - 4
Description0.1 GHz to 24 GHz, Low Noise, Programmable Divider
Pages / Page15 / 4 — HMC862A. Data Sheet. DC SPECIFICATIONS. Table 2. Parameter Test. …
File Format / SizePDF / 483 Kb
HMC862A. Data Sheet. DC SPECIFICATIONS. Table 2. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
HMC862A Data Sheet DC SPECIFICATIONS Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
VCC = 5 V, TA = −40°C to +85°C, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
POWER SUPPLIES VCC Analog supply 4.75 5 5.25 V CURRENT CONSUMPTION, ICC N = 1 55 61 71 mA N = 2 64 73 84 mA N = 4 68 78 90 mA N = 8 71 81 94 mA DIGITAL INPUT S (S0, S1, S2) Logic Voltage Low 0 0.4 V High 3 5 V Rev. A | Page 4 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
