Datasheet HMC862A (Analog Devices) - 3
Description | 0.1 GHz to 24 GHz, Low Noise, Programmable Divider |
Pages / Page | 15 / 3 — Data Sheet. HMC862A. SPECIFICATIONS RF SPECIFICATIONS. Table 1. Parameter … |
Revision | A |
File Format / Size | PDF / 483 Kb |
Data Sheet. HMC862A. SPECIFICATIONS RF SPECIFICATIONS. Table 1. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
link to page 7
Data Sheet HMC862A SPECIFICATIONS RF SPECIFICATIONS
VCC = 5 V, TA = −40°C to +85°C, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
RF INPUT CHARACTERISTICS RF Input Frequency Maximum Sine wave or square wave input N = 1 18 GHz N = 2, 4, 8 24 GHz Minimum Square wave input1 0.1 GHz RF Input Power Range N = 1, 2 0.1 GHz< fIN < 18 GHz, sine or square wave input1 −15 +10 dBm N = 2 18 GHz < fIN < 24 GHz, sine or square wave input −5 +10 dBm N = 4, 8 0.1 GHz < fIN < 20 GHz, sine or square wave input1 −15 +10 dBm 20 GHz < fIN < 24 GHz, sine or square wave input −5 +10 dBm Reverse Leakage N = 1 fIN = 6 GHz, input power (PIN) = 0 dBm −10 dBm N = 2 fIN = 6 GHz, PIN = 0 dBm −55 dBm N = 4, 8 fIN = 6 GHz, PIN = 0 dBm −70 dBm RF OUTPUT CHARACTERISTICS, N = 1 Output Power, Single-Ended 0.1 GHz < fIN < 10 GHz −1 +3 +5 dBm 10 GHz < fIN < 15 GHz −5 −2 +3 dBm 15 GHz < fIN < 18 GHz −11 −6 0 dBm Single-Sideband (SSB) Residual Phase Noise fIN = 12 GHz, PIN = 5 dBm −155 dBc/Hz at 100 kHz Offset Second Harmonic fIN = 6 GHz, PIN = 0 dBm −27 dBm Third Harmonic fIN = 6 GHz, PIN = 0 dBm −6 dBm RF OUTPUT CHARACTERISTICS, N = 2 Output Power, Single-Ended 0.1 GHz < fIN < 18 GHz 0 3 5 dBm 18 GHz < fIN < 24 GHz −3 0 +3 dBm SSB Residual Phase Noise at 100 kHz Offset fIN = 12 GHz, PIN = 5 dBm −153 dBc/Hz Second Harmonic (Feedthrough) fIN = 6 GHz, PIN = 0 dBm −28 dBm Third Harmonic fIN = 6 GHz, PIN = 0 dBm −7 dBm RF OUTPUT CHARACTERISTICS, N = 4 Output Power, Single-Ended 0.1 GHz < fIN < 18 GHz 0 2 4 dBm 18 GHz < fIN < 24 GHz −1 +3 +6 dBm SSB Residual Phase Noise at 100 kHz Offset fIN = 12 GHz, PIN = 5 dBm −154 dBc/Hz Second Harmonic fIN = 6 GHz, PIN = 0 dBm −35 dBm Third Harmonic fIN = 6 GHz, PIN = 0 dBm −6 dBm RF OUTPUT CHARACTERISTICS, N = 8 Output Power, Single-Ended 0.1 GHz < fIN < 24 GHz 0 2 4 dBm SSB Residual Phase Noise at 100 kHz Offset fIN = 12 GHz, PIN = 5 dBm −155 dBc/Hz Second Harmonic fIN = 6 GHz, PIN = 0 dBm −45 dBm Third Harmonic fIN = 6 GHz, PIN = 0 dBm −7 dBm 1 A square wave input is recommended to be below 650 MHz for best phase noise performance. If a sine wave input below 650 MHz is used, it is recommended that the drive level be >5 dBm for best operation, including phase noise. Refer to the Typical Performance Characteristics section. Rev. A | Page 3 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
