Datasheet HMC862A (Analog Devices) - 7
Description0.1 GHz to 24 GHz, Low Noise, Programmable Divider
Pages / Page15 / 7 — Data Sheet. HMC862A. TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1. R …
RevisionA
File Format / SizePDF / 483 Kb
Data Sheet. HMC862A. TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1. R (. –18. +85°C. VCC = 5.25V. –10. +25°C. VCC = 5.0V. –40°C
Data Sheet HMC862A TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 R ( –18 +85°C VCC = 5.25V –10 +25°C VCC = 5.0V –40°C
Data Sheet HMC862A TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 6 6 4 4 2 2 ) ) Bm 0 Bm d 0 d R ( R ( E –2 E –2 W W O O P –4 P –4 UT UT P P –6 –6 UT UT O O –18 –18 +85°C VCC = 5.25V –10 +25°C –10 VCC = 5.0V –40°C VCC = 4.75V –12 –12 0 2 4 6 8 10 12 14 16 18 20
09 10 0
0 9- 9-
SINE WAVE INPUT FREQUENCY (GHz)
59
59 13 13 Figure 3. Output Power vs. Sine Wave Input Frequency for Various Figure 6. Output Power vs. Sine Wave Input Frequency for Various VCC Temperatures, PIN = 0 dBm Voltages, PIN = 0 dBm
15 0 MAX PIN 10 –10 5 ) ) m Bm d B –20 0 (d R ( R E E +85°C W W –5 +25°C O –30 –40°C PO C P T NI –10 O PU –40 IN –15 HARM MIN PIN –50 –20 SECOND HARMONIC THIRD HARMONIC –25
1
–60 0 2 4 6 8 10 12 14 16 18 20 22
1 12 0
0 9- 9-
59
OUTPUT FREQUENCY (GHz)
59 13 13 Figure 4. Allowable Range of Input Power vs. Sine Wave Input Frequency Figure 7. Output Harmonics, PIN = 0 dBm, TA = 25°C for Various Temperatures
–115 –115 SQUARE 100MHz P –120 IN = +10dBm SINE 100MHz (5dBm) –120 PIN = +5dBm SINE 12GHz PIN = 0dBm –125 SINE 6GHz –125 PIN = –5dBm z) z) PIN = –10dBm c/H –130 c/H –130 B B d d –135 –135 ISE ( ISE ( O –140 O –140 N N SE –145 SE A –145 A PH –150 PH –150 SSB SSB –155 –155 –160 –160 –165 –165 100 1k 10k 100k 1M
013
100 1k 10k 100k 1M
014 99- 99-
OFFSET FREQUENCY (Hz) OFFSET FREQUENCY (Hz)
135 135 Figure 5. SSB Phase Noise vs. Offset Frequency for Various Input Frequencies, Figure 8. SSB Phase Noise vs. Offset Frequency for Various Input Power (PIN) PIN = 0 dBm, TA = 25°C Levels, fIN = 12 GHz Sine Wave, TA = 25°C Rev. A | Page 7 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
