Datasheet HMC862A (Analog Devices) - 8
Description0.1 GHz to 24 GHz, Low Noise, Programmable Divider
Pages / Page15 / 8 — HMC862A. Data Sheet. DIVIDE BY 2. R (. +85°C. CC = 5.25V. +25°C. CC = …
File Format / SizePDF / 483 Kb
HMC862A. Data Sheet. DIVIDE BY 2. R (. +85°C. CC = 5.25V. +25°C. CC = 5.00V. –40°C. CC = 4.75V. SINE WAVE INPUT FREQUENCY (GHz). MAX PIN. –10
HMC862A Data Sheet DIVIDE BY 2 R ( +85°C CC = 5.25V +25°C CC = 5.00V –40°C CC = 4.75V SINE WAVE INPUT FREQUENCY (GHz) MAX PIN –10
HMC862A Data Sheet DIVIDE BY 2 6 6 4 4 ) ) Bm 2 Bm d 2 d R ( R ( E E W 0 W O 0 O P P UT UT P P –2 –2 UT UT O O –4 V +85°C –4 CC = 5.25V V +25°C CC = 5.00V V –40°C CC = 4.75V –6 –6 0 2 4 6 8 10 12 14 16 18 20 22 24
21 22 0
0 9- 9-
59
59 13 13 Figure 9. Output Power vs. Sine Wave Input Frequency for Various Figure 12. Output Power vs. Sine Wave Input Frequency for Various VCC Temperatures, PIN = 0 dBm Voltages, PIN = 0 dBm
15 0 MAX PIN 10 –10 5 ) ) m Bm d B +85°C –20 0 +25°C (d R ( R –40°C E E W W –5 O –30 PO C P T NI –10 O PU –40 IN –15 HARM MIN PIN –50 –20 FEEDTHROUGH THIRD HARMONIC –25 –60 0 2 4 6 8 10 12 14 16 18 20 22 24
23 24 0
0 2 4 6 8 10 12
0 9- 9-
59
OUTPUT FREQUENCY (GHz)
59 13 13 Figure 10. Allowable Range of Input Power vs. Sine Wave Input Frequency Figure 13. Output Harmonics, PIN = 0 dBm, TA = 25°C for Various Temperatures
–115 –115 SQUARE 100MHz P –120 SINE 100MHz (5dBm) –120 IN = +10dBm P SINE 18GHz IN = +5dBm PIN = 0dBm –125 SINE 12GHz –125 PIN = –5dBm z) SINE 6GHz z) PIN = –10dBm c/H –130 c/H –130 B B d d ( –135 ( E –135 E IS IS O –140 O –140 N N E E –145 –145 HAS HAS –150 B P –150 B P S S S S –155 –155 –160 –160 –165
5
–165
6
100 1k 10k 100k 1M
02
100 1k 10k 100k 1M
02
OFFSET FREQUENCY (Hz) OFFSET FREQUENCY (Hz)
13599- 13599- Figure 11. SSB Phase Noise vs. Offset Frequency for Various Input Figure 14. SSB Phase Noise vs. Offset Frequency for Various Input Power (PIN) Frequencies, PIN = 0 dBm, TA = 25°C Levels, fIN = 12 GHz Sine Wave, TA = 25°C Rev. A | Page 8 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS RF SPECIFICATIONS DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS DIVIDE BY 1 DIVIDE BY 2 DIVIDE BY 4 DIVIDE BY 8 CURRENT CONSUMPTION (ICC) THEORY OF OPERATION INPUT INTERFACE OUTPUT INTERFACE APPLICATIONS INFORMATION EVALUATION PRINTED CIRCUIT BOARD (PCB) EVALUATION BOARD OVERVIEW OUTLINE DIMENSIONS ORDERING GUIDE
