Datasheet ADRV9008-1 (Analog Devices) - 67
DescriptionIntegrated Dual RF Receiver
Pages / Page68 / 67 — Data Sheet. ADRV9008-1
Data Sheet ADRV9008-1
link to page 67
Table 9 and shows the selected balun and component values The RF matching used in the ADRV9008-1W/PCBZ allows the used for three matching network sets. Refer to the ADRV9008-1 ADRV9008-1 to operate across the entire chip frequency range schematics for a wideband matching example that operates across with slightly reduced performance. the entire device frequency range with somewhat reduced performance.
Table 9. Receiver 1 and Receiver 2 Evaluation Board Matching Components for Frequency Band 75 MHz to 6000 MHz Component Value
C201, C208 Do not install (DNI) R202, R209 0 Ω C203, C210 DNI C248, C249 18 pF C204, C211 DNI R205/R206, R212/R213 0 Ω C207, C214 DNI T201, T202 Mini circuits TMC1-83X+ Rev. 0 | Page 67 of 68 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Current and Power Consumption Specifications Timing Diagrams Absolute Maximum Ratings Reflow Profile Thermal Management Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics 75 MHz to 525 MHz Band 650 MHz to 3000 MHz Band 3400 MHz to 4800 MHz Band 5100 MHz to 5900 MHz Band Receiver Input Impedance Terminology Theory of Operation Receivers Clock Input Synthesizers RF PLL Clock PLL SPI JTAG Boundary Scan Power Supply Sequence GPIO_x Pins Auxiliary Converters AUXADC_x Auxiliary DAC x JESD204B Data Interface Applications Information PCB Layout and Power Supply Recommendations Overview PCB Material and Stackup Selection Fanout and Trace Space Guidelines Component Placement and Routing Guidelines Signals with Highest Routing Priority Signals with Second Routing Priority Signals with Lowest Routing Priority RF and JESD204B Transmission Line Layout RF Routing Guidelines JESD204B Trace Routing Recommendations Routing Recommendations Stripline Transmission Lines vs. Microstrip Transmission Lines Isolation Techniques Used on the ADRV9008-1W/PCBZ Isolation Goals Isolation Between JESD204B Lines RF Port Interface Information RF Port Impedance Data Advanced Design System (ADS) Setup Using the DataAccessComponent and SEDZ File General Receiver Path Interface Impedance Matching Network Examples Outline Dimensions Ordering Guide
