Datasheet AD534 (Analog Devices) - 6
DescriptionInternally Trimmed Precision IC Multiplier
Pages / Page20 / 6 — AD534. Data Sheet. AD534S. AD534T. Parameter. Min. Typ. Max. Unit
RevisionD
File Format / SizePDF / 334 Kb
AD534 Data Sheet AD534S AD534T Parameter Min Typ Max Unit
link to page 1 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6 link to page 6
AD534 Data Sheet AD534S AD534T Parameter Min Typ Max Min Typ Max Unit
DIVIDER PERFORMANCE Transfer Function (X1 > X2) (Z  Z ) (Z  Z ) 2 1 10 V Y 2 1 10 V Y 1 (X  X ) 1 (X  X ) 1 2 1 2 Total Error1 X = 10 V, −10 V ≤ Z ≤ +10 V ±0.75 ±0.35 % X = 1 V, −1 V ≤ Z ≤ +1 V ±2.0 ±1.0 % 0.1 V ≤ X ≤ 10 V, −10 V ≤ Z ≤ +10 V ±2.5 ±1.0 % SQUARER PERFORMANCE Transfer Function (X  X )2 (X  X )2 1 2 Z 1 2 Z 2 10 V 2 10 V Total Error (−10 V ≤ X ≤ +10 V) ±0.6 ±0.3 % SQUARE-ROOTER PERFORMANCE Transfer Function (Z1 ≤ Z2) √(10 V(Z2 – Z1)) + X2 √(10 V(Z2 – Z1)) + X2 Total Error1 (1 V ≤ Z ≤ 10 V) ±1.0 ±0.5 % POWER SUPPLY SPECIFICATIONS Supply Voltage Rated Performance ±15 ±15 V Operating ±8 ±222 ±8 ±222 V Supply Current Quiescent 4 62 4 62 mA 1 Specifications given are percent of full scale, ±10 V (that is, 0.01% = 1 mV). 2 Tested on all production units at final electrical test. Results from those tests are used to calculate outgoing quality levels. 3 Can be reduced down to 3 V using external resistor between –VS and SF. 4 Irreducible component due to nonlinearity: excludes effect of offsets. 5 Using external resistor adjusted to give SF = 3 V. 6 See Figure 1 for definition of sections. Rev. D | Page 6 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Description Provides Gain with Low Noise Operation as a Multiplier Operation as a Squarer Operation as a Divider Operation as a Square Rooter Unprecedented Flexibility Applications Information Outline Dimensions Ordering Guide
