Datasheet AD534 (Analog Devices) - 7
DescriptionInternally Trimmed Precision IC Multiplier
Pages / Page20 / 7 — Data Sheet. AD534. ABSOLUTE MAXIMUM RATINGS. OUT. Table 3. AD534J,. 5 3. …
RevisionD
File Format / SizePDF / 334 Kb
Data Sheet. AD534. ABSOLUTE MAXIMUM RATINGS. OUT. Table 3. AD534J,. 5 3. AD534K,. AD534S,. 4 8. Parameter. AD534L. AD534T. 0.076. (1.93)
Data Sheet AD534 ABSOLUTE MAXIMUM RATINGS OUT Table 3 AD534J, 5 3 AD534K, AD534S, 4 8 Parameter AD534L AD534T 0.076 (1.93)
Data Sheet AD534 ABSOLUTE MAXIMUM RATINGS X +V 1 S OUT Table 3. X AD534J, 2 5 3 AD534K, AD534S, 4 8 Parameter AD534L AD534T A
Supply Voltage ±18 V ±22 V
0.076 (1.93)
Internal Power Dissipation 500 mW 500 mW
SF
Output Short Circuit to
Z1
Ground Indefinite Indefinite Input Voltages (X1, X2, Y1, Y2, Z1, Z2) ±VS ±VS Rated Operating Temperature Range 0°C to +70°C −55°C to +125°C Storage Temperature
Y1
Range −65°C to +150°C −65°C to +150°C 4 Lead Temperature Range,
Y –V Z
00
2 S 2
5- 60 sec Soldering 300°C 300°C 67
0.100 (2.54)
09 Stresses above those listed under Absolute Maximum Ratings Figure 2. Chip Dimensions and Bonding Diagram Dimensions shown in inches and (mm) may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any Contact factory for latest dimensions. other conditions above those indicated in the operational
+VS
section of this specification is not implied. Exposure to absolute
470kΩ
maximum rating conditions for extended periods may affect
50kΩ TO APPROPRIATE INPUT TERMINAL
device reliability.
1kΩ
005
THERMAL RESISTANCE
675-
–VS
09 θ Figure 3. Optional Trimming Configuration JA is specified for the worst-case conditions, that is, a device soldered in a circuit board for surface-mount packages.
ESD CAUTION Table 4. Thermal Resistance Package Type θJA θJC Unit
10-Pin TO-100 (H-10) 150 25 °C/W 14-Lead SBDIP (D-14) 95 25 °C/W 20-Terminal LCC (E-20-1) 95 25 °C/W Rev. D | Page 7 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Functional Description Provides Gain with Low Noise Operation as a Multiplier Operation as a Squarer Operation as a Divider Operation as a Square Rooter Unprecedented Flexibility Applications Information Outline Dimensions Ordering Guide
