Datasheet AD532 (Analog Devices) - 8
DescriptionInternally Trimmed Integrated Circuit Multiplier
Pages / Page14 / 8 — AD532. Data Sheet. SATURATED OUTPUT. E (±. SWING. VO L. MAX X OR Y INPUT. …
RevisionE
File Format / SizePDF / 348 Kb
AD532. Data Sheet. SATURATED OUTPUT. E (±. SWING. VO L. MAX X OR Y INPUT. ISE (µ. FOR 1% LINEARITY. SI K. SPO. PEA. 100. 10k. 100k
AD532 Data Sheet SATURATED OUTPUT E (± SWING VO L MAX X OR Y INPUT ISE (µ FOR 1% LINEARITY SI K SPO PEA 100 10k 100k
AD532 Data Sheet 14 5 12 4 V) SATURATED OUTPUT E (± z) G SWING A H T 10 V/ 3 L VO L MAX X OR Y INPUT ISE (µ A FOR 1% LINEARITY O N 8 N G 2 T SI K SPO PEA 6 1 4 0 10 12 14 16 18 20 22
011
10 100 1k 10k 100k
012
POWER SUPPLY VOLTAGE (V) FREQUENCY (Hz)
00502- 00502- Figure 11. Signal Swing vs. Supply Figure 12. Spot Noise vs. Frequency Rev. E | Page 8 of 14 Document Outline Features Applications General Description Flexibility of Operation Functional Block Diagram Guaranteed Performance Over Temperature Advantages of On The Chip Trimming of The Monolithic AD532 Revision History Specifications Thermal Resistance Chip Dimensions And Bonding Diagram ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Functional Description AD532 Performance Characteristics Nonlinearity AC Feedthrough Common-Mode Rejection Dynamic Characteristics Power Supply Considerations Noise Characteristics Applications Replacing Other IC Multipliers Multiplication Squaring Division Square Root Additional Information Outline Dimensions Ordering Guide
