Datasheet LTC6226, LTC6227 (Analog Devices) - 8
Description1nV/√Hz 420MHz GBW, 180V/µs, Low Distortion Rail-to-Rail Output Op Amps
Pages / Page28 / 8 — ELECTRICAL CHARACTERISTICS (V. The. denotes the specifications which …
ELECTRICAL CHARACTERISTICS (V. The. denotes the specifications which apply. S = 3V, 0V)
ELECTRICAL CHARACTERISTICS (V The denotes the specifications which apply S = 3V, 0V)
link to page 9 link to page 9 LTC6226/LTC6227
l
denotes the specifications which apply S = 3V, 0V) over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 3V, 0V,VCM = 1.5V, VSHDN = floating unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
PSRR– Negative Power Supply Rejection Ratio V+ = 1.5V, V– = –1.3V to –10.25V 103 127 dB l 100 dB Supply Voltage Range (V+ – V–) (Note 7) l 2.8 11.75 V VOL Output Swing Low (VOUT – VEE) No Load 12 14 mV l 18 mV ISINK = 5mA 91 121 mV l 160 mV ISINK = 10mA 161 205 mV l 275 mV VOH Output Swing High (VCC – VOUT) No Load 10 14 mV l 18 mV ISINK = 5mA 150 180 mV l 230 mV ISOURCE = 10mA 250 330 mV l 430 mV ISC Output Short Circuit Current Sourcing 47 mA Sinking 57 mA IS Supply Current/Channel 5.5 6 mA l 7.25 mA ISD Disable Supply Current, Amplifier Off VSHDN = V+ – 2.65V l 195 247 μA 278 µA VL_SHDN SHDN Pin Input Voltage Low, Disable Amplifier l V+ – 2.65 V VH_SHDN SHDN Pin Input Voltage High, Enable Amplifier l V+ – 1.6 V IL_SHDN SHDN Pin Input Current, Disable Amplifier VSHDN = V+ – 2.65V l –10 –2.9 10 μA IH_SHDN SHDN Pin Input Current, Enable Amplifier VSHDN = V+ – 1.6V l –10 0.3 10 μA IOSD Output Leakage Current in Shutdown 100 nA BW –3dB Closed Loop Bandwidth AV = 1, RL = 1kΩ to Half Supply 450 MHz GBW Gain-Bandwidth Product f = 5MHz, RL = 1kΩ to Half Supply 340 415 MHz l 280 MHz tON Turn-On Time VSHDN = V+ – 2.65V to V+ – 1.6V 2100 ns tOFF Turn-Off Time VSHDN = V+ – 1.6V to V+ – 2.65V 800 ns tS_0.1 Settling Time to 0.1% AV = 1, VCM = 1V, 1V Output Step, 84 ns RL = 1kΩ to VCM SR Slew Rate (Note 9) AV = +4, 2V Output Step 100 V/μS FPBW Full Power Bandwidth VOUT = 2VP-P, AV = –1, THD < –40dBc 8 MHz Rev 0 8 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics (VS = ±5V) Electrical Characteristics (VS = 5V, 0V) Electrical Characteristics (VS = 3V, 0V) Typical Performance Characteristics Pin Functions Applications Information Typical Applications Package Description Typical Application Related Parts
