Datasheet VCNL3030X01 (Vishay) - 2
ManufacturerVishay
DescriptionFully Integrated Proximity Sensor With Infrared Emitter, I2C Interface, and Interrupt Function
Pages / Page16 / 2 — VCNL3030X01. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). …
File Format / SizePDF / 271 Kb
VCNL3030X01. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). REMARKS. Note. SLAVE ADDRESS OPTIONS ORDERING CODE
VCNL3030X01 ORDERING INFORMATION ORDERING CODE PACKAGING VOLUME (1) REMARKS Note SLAVE ADDRESS OPTIONS ORDERING CODE
VCNL3030X01
VCNL3030X01-GS08 MOQ: 3300 pcs Tape and reel 4.0 mm x 2.36 mm x 0.75 mm VCNL3030X01-GS18 MOQ: 13 000 pcs
Note
(1) MOQ: minimum order quantity
SLAVE ADDRESS OPTIONS ORDERING CODE SLAVE ADDRESS (7 bit)
VCNL3030X01-GS08 0x41 VCNL3030X01-GS18
ABSOLUTE MAXIMUM RATINGS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 2.5 3.6 V Operation temperature range Tamb -40 +105 °C Storage temperature range Tstg -40 +110 °C
RECOMMENDED OPERATING CONDITIONS
Supply voltage VDD 2.5 3.6 V Operation temperature range Tamb -40 +105 °C I2C bus operating frequency f(I2CCLK) 10 400 kHz
PIN DESCRIPTIONS PIN ASSIGNMENT SYMBOL TYPE FUNCTION
1 VDD - Power supply input 2 SCL I I2C digital bus clock input 3 GND - Ground 4 IR ANODE I Anode for IRED 5 IR CATHODE I Cathode (IRED) connection 6 LDR I IRED driver input 7 INT O Interrupt pin 8 SDA I / O (open drain) I2C data bus data input / output Rev. 1.0, 12-Aug-2020
2
Document Number: 84960 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
