Datasheet VCNL3030X01 (Vishay) - 3
ManufacturerVishay
DescriptionFully Integrated Proximity Sensor With Infrared Emitter, I2C Interface, and Interrupt Function
Pages / Page16 / 3 — VCNL3030X01. BLOCK DIAGRAM. BASIC CHARACTERISTICS. PARAMETER. TEST …
File Format / SizePDF / 271 Kb
VCNL3030X01. BLOCK DIAGRAM. BASIC CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. Notes
VCNL3030X01 BLOCK DIAGRAM BASIC CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT Notes
VCNL3030X01
BLOCK DIAGRAM VCNL3030X01
V 8 SDA DD 1 PS data buffer SCL 2 7 INT C interface Output buffer 2 I -PD S P DSP cillator GND 3 s 6 LDR Driver O Temperature compensation IR anode 4 5 IR cathode Fig. 1 - Detailed Block Diagram
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Supply voltage VDD 2.5 - 3.6 V Excluded LED driving IDD - 200 - μA Supply current Light condition = dark, VDD = 3.3 V IDD (SD) - 0.2 - μA I2C supply voltage VPULL UP 1.8 - 5.5 V Logic high VIH 1.55 - - VDD = 3.3 V V Logic low VIL - - 0.4 I2C signal input Logic high VIH 1.4 - - VDD = 2.6 V V Logic low VIL - - 0.4 Peak sensitivity wavelength of PS λp - 720 - nm Full PS counts 12-bit / 16-bit resolution - - 4096 / 65 535 steps PS detection range Kodak gray card (1) 0 - 300 mm Operating temperature range Tamb -40 - +105 °C LED_Anode voltage - - 5.5 V IRED driving current (2) - 200 - mA
Notes
• Test condition: VDD = 3.3 V, temperature: 25 °C (1) Part should be operated in dark condition (not in direct sunlight) (2) Programmable between 50 mA and 200 mA; based on IRED on / off duty ratio = 1/40, 1/80, 1/160, and 1/320 Rev. 1.0, 12-Aug-2020
3
Document Number: 84960 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
