Datasheet MAX4389, MAX4390, MAX4392–MAX4396 (Maxim) - 6
ManufacturerMaxim
DescriptionUltra-Small, Low-Cost, 85MHz Op Amps with Rail-to-Rail Outputs and Disable
Pages / Page17 / 6 — Typical Operating Characteristics. GAIN AND PHASE. SMALL-SIGNAL GAIN. …
File Format / SizePDF / 2.5 Mb
Typical Operating Characteristics. GAIN AND PHASE. SMALL-SIGNAL GAIN. LARGE-SIGNAL GAIN. vs. FREQUENCY. FLATNESS vs. FREQUENCY
Typical Operating Characteristics GAIN AND PHASE SMALL-SIGNAL GAIN LARGE-SIGNAL GAIN vs FREQUENCY FLATNESS vs FREQUENCY
MAX4389/MAX4390/ Ultra-Small, Low-Cost, 85MHz Op Amps with MAX4392–MAX4396 Rail-to-Rail Outputs and Disable
(VCC = 5V, VEE = -5V, VCM = 0V, AVCL = 1V/V, RL = 100Ω to GND, GND = 0, TA = +25°C, unless otherwise noted.)
GAIN AND PHASE SMALL-SIGNAL GAIN LARGE-SIGNAL GAIN vs. FREQUENCY vs. FREQUENCY vs. FREQUENCY
MAX4389 toc01 80 180 4 4 V V 60 135 3 OUT = 100mVP-P 3 OUT = 2VP-P GAIN MAX4389 toc02 40 90 2 MAX4389 toc03 2 20 45 1 1 0 0 0 0 -20 -45 -1 -1 GAIN (dB) GAIN (dB) -40 PHASE -90 -2 GAIN (dB) -2 -60 PHASE (DEGREES) -135 -3 -3 -80 -180 -4 -4 -100 -225 -5 -5 -120 -270 -6 -6 1k 10k 100k 1M 10M 100M 1G 100k 1M 10M 100M 1G 100k 1M 10M 100M 1G FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
SMALL-SIGNAL GAIN LARGE-SIGNAL GAIN FLATNESS vs. FREQUENCY FLATNESS vs. FREQUENCY OUTPUT IMPEDANCE vs. FREQUENCY
0.4 0.4 100 VOUT = 100mVP-P VOUT = 2VP-P 0.3 0.3 MAX4389 toc04 0.2 MAX4389 toc05 0.2 MAX4389 toc06 ) Ω 10 0.1 0.1 0 0 -0.1 -0.1 1 GAIN (dB) -0.2 GAIN (dB) -0.2 -0.3 -0.3 OUTPUT IMPEDANCE ( 0.1 -0.4 -0.4 -0.5 -0.5 -0.6 -0.6 0.01 100k 1M 10M 100M 1G 100k 1M 10M 100M 1G 100k 1M 10M 100M 1G FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
DISTORTION vs. FREQUENCY DISTORTION vs. FREQUENCY DISTORTION vs. FREQUENCY
0 0 0 V V V -10 OUT = 2VP-P, AVCL = 1V/V -10 OUT = 2VP-P, AVCL = 2V/V -10 OUT = 2VP-P, AVCL = 5V/V MAX4389 toc07 -20 MAX4389 toc08 -20 MAX4389 toc09 -20 -30 -30 -30 -40 -40 -40 3RD HARMONIC -50 -50 -50 -60 -60 3RD HARMONIC -60 2ND HARMONIC DISTORTION (dBc) 2ND HARMONIC -70 2ND HARMONIC DISTORTION (dBc) -70 DISTORTION (dBc) -70 -80 -80 -80 3RD HARMONIC -90 -90 -90 -100 -100 -100 100k 1M 10M 100M 100k 1M 10M 100M 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) www.maximintegrated.com Maxim Integrated │ 6
