Datasheet MAX4389, MAX4390, MAX4392–MAX4396 (Maxim) - 7
Manufacturer | Maxim |
Description | Ultra-Small, Low-Cost, 85MHz Op Amps with Rail-to-Rail Outputs and Disable |
Pages / Page | 17 / 7 — Typical Operating Characteristics (continued). DISTORTION vs. RESISTIVE … |
File Format / Size | PDF / 2.5 Mb |
Typical Operating Characteristics (continued). DISTORTION vs. RESISTIVE LOAD. DISTORTION vs. VOLTAGE SWING
MAX4389/MAX4390/ Ultra-Small, Low-Cost, 85MHz Op Amps with MAX4392–MAX4396 Rail-to-Rail Outputs and Disable
(VCC = 5V, VEE = -5V, VCM = 0V, AVCL = 1V/V, RL = 100Ω to GND, GND = 0, TA = +25°C, unless otherwise noted.)
DISTORTION vs. RESISTIVE LOAD DISTORTION vs. VOLTAGE SWING DIFFERENTIAL GAIN AND PHASE
0 0 0.1 f f R -10 o = 5MHz, VOUT = 2VP-P, AVCL = 1V/V -10 o = 5MHz, AVCL = 1V/V 0 L = 150Ω TO GND, AVCL = 2V/V -0.1 MAX4389 toc10 -20 MAX4389 toc11 -20 MAX4389 toc12 -0.2 -30 -30 -0.3 -40 -40 DIFF GAIN (%) -0.4 -0.5 -50 -50 0.5 -60 -60 3RD HARMONIC 0.4 DISTORTION (dBc) 2ND HARMONIC -70 DISTORTION (dBc) -70 2ND HARMONIC 0.3 0.2 -80 -80 0.1 -90 3RD HARMONIC -90 DIFF PHASE (°) 0 RL = 150Ω TO GND, AVCL = 2V/V -100 -100 -0.1 0 200 400 600 800 1000 1200 0.5 1.0 1.5 2.0 0 1 2 3 4 5 6 VOLTAGE SWING (VP-P) VOLTAGE SWING (VP-P) IRE
COMMON-MODE REJECTION POWER-SUPPLY REJECTION OUTPUT VOLTAGE SWING vs. FREQUENCY vs. FREQUENCY vs. RESISTIVE LOAD
0 0 1.6 -10 -10 1.4 MAX4389 toc13 MAX4389 toc14 MAX4389 toc15 -20 1.2 -20 -30 1.0 -30 -40 0.8 GAIN (dB) PSR (dB) -40 -50 0.6 VCC - VOH -60 -50 0.4 OUTPUT VOLTAGE SWING (V) -70 -60 0.2 VOL- VEE -80 -70 0 100k 1M 10M 100M 1G 100k 1M 10M 100M 1G 0 100 200 300 400 500 600 FREQUENCY (Hz) FREQUENCY (Hz) RLOAD (Ω)
SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE SMALL-SIGNAL PULSE RESPONSE
AVCL = 1V/V AVCL A = +2V/V VCL = 2V/V AVCL = 5V/V RF R = 200 F = 200 RF = 250 MAX4389 toc16 INPUT MAX4389 toc17 INPUT MAX4389 toc18 INPUT 50mV/div 25mV/div 10mV/div OUTPUT OUTPUT OUTPUT 50mV/div 50mV/div 50mV/div 20ns/div 20ns/div 20ns/div www.maximintegrated.com Maxim Integrated │ 7
