HMC5805ALS6 v02.0517 GaAs pHEMT MMIC 0.25 WATT POWER AMPLIFIERDC - 40 GHzPin Descriptions Pin Number Function Description Interface Schematic T Low frequency termination. Attach bypass ACG2 M capacitor per application circuit herein. Low frequency termination. Attach bypass ACG1 1, 2, 14 capacitor per application circuit herein. RF output for amplifier. Connect DC bias (VDD) network R - S RFOUT & VDD to provide drain current (Idd). See application circuit E herein. W Gate control 2 for amplifier. Attach bypass O 3 VGG2 capacitors per application circuit herein. For normal operation +3.5V should be applied to Vgg2. This pin is DC coupled and matched R & P 6 RFIN to 50 Ohms. Blocking capacitor is required. A E Gate control 1 for amplifier. Attach bypass IN capacitors per application circuit herein. Please 9 VGG1 follow “MMIC Amplifier Biasing Procedure” application note. S - L Low frequency termination. Attach bypass 10 ACG4 capacitor per application circuit herein. R Low frequency termination. Attach bypass IE 11 ACG3 capacitor per application circuit herein. LIF These pins and exposed ground paddle must be P 5, 7, 13, 15 GND connected to RF/DC ground. M These pins are not connected internally; however, all data A 4, 8, 12, 16 N/C shown herein was measured with these pins connected to RF/DC ground externally. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com 7 Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Typical Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature P1dB vs. Temperature Psat vs. Temperature Psat vs. Supply Voltage P1dB vs. Supply Current Psat vs. Supply Current Output IP3 vs. Temperature @ Pout = 14 dBm / Tone Output IP3 vs. Supply Voltage @ Pout = 14 dBm / Tone Output IP3 vs. Supply Currents @ Pout = 14 dBm / Tone Output IM3 @ Vdd = +10V Output IM3 @ Vdd = +11V Reverse Isolation vs. Temperature Power Compression @ 20 GHz Absolute Maximum Ratings Outline Drawing Pad Descriptions Application Circuit
