Datasheet HMC383LC4 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz
Pages / Page6 / 4 — HMC383LC4. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Absolute …
File Format / SizePDF / 375 Kb
HMC383LC4. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC383LC4 GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC383LC4
v05.0514
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd) +5.5 Vdc Vdd (V) Idd (mA) RF Input Power (RFIN)(Vdd = +5Vdc) +10 dBm +4.5 99 T Channel Temperature 175 °C +5.0 100 M Continuous Pdiss (T= 85 °C) +5.5 101 0.92 W (derate 10 mW/°C above 85 °C) Note: Amplifier will operate over full voltage ranges shown above Thermal Resistance 98 °C/W (channel to ground paddle) S - S Storage Temperature -65 to +150 °C R Operating Temperature -40 to +85 °C ELECTROSTATIC SENSITIVE DEVICE IE ESD Sensitivity (HBM) Class 1A OBSERVE HANDLING PRECAUTIONS LIF P M
Outline Drawing
R A E W O R & P A E LIN NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA 2. LEAD AND GROUND PADDLE PLATING: 30-80 MICROINCHES GOLD OVER 50 MICROINCHES MINIMUM NICKEL. 3. ALL DIMENSIONS ARE IN INCHES [MM] 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm DATUM -C- 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC383LC4 Alumina, White Gold over Nickel MSL3 [1] H383 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
