Datasheet HMC383LC4 (Analog Devices)
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz
Pages / Page6 / 1 — HMC383LC4. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Typical …
File Format / SizePDF / 375 Kb
HMC383LC4. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC383LC4 Analog Devices
HMC383LC4
v05.0514
GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz Typical Applications Features
The HMC383LC4 is ideal for: Gain: 15 dB T • Point-to-Point Radios Saturated Output Power: +18 dBm M • Point-to-Multi-Point Radios & VSAT Output IP3: +25 dBm • Test Equipment & Sensors Single Positive Supply: +5V @ 100 mA S - S • LO Driver for HMC Mixers 50 Ohm Matched Input/Output R • Military & Space RoHS Compliant 4x4 mm Package IE LIF P
M The HMC383LC4 is a general purpose GaAs PHEMT MMIC Driver Amplifier housed in a leadless RoHS R A compliant SMT package. The amplifier provides 15 dB E of gain and +18 dBm of saturated power from a single W +5V supply. Consistent gain and output power across O the operating band make it possible to use a com- mon driver/LO amplifier approach in multiple radio bands. The RF I/Os are DC blocked and matched to 50 Ohms for ease of use. The HMC383LC4 is housed R & P in a RoHS compliant leadless 4x4 mm package A al owing the use of surface mount manufacturing E techniques. LIN
Electrical Specifications, T = +25° C, Vdd = +5V A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 12 - 16 16 -24 24 - 28 28 - 30 GHz Gain 12 15 13 16 12 15 10 13 dB Gain Variation Over Temperature 0.02 0.03 0.02 0.03 0.02 0.03 0.02 0.03 dB/ °C Input Return Loss 14 14 11 13 dB Output Return Loss 14 17 10 8 dB Output Power for 1 dB Compression 12 15 13.5 16.5 13 16 12 15 dBm (P1dB) Saturated Output Power (Psat) 17 18 17 16 dBm Output Third Order Intercept (IP3) 24 25 25 23 dBm Noise Figure 10.5 8 7.5 8 dB Supply Current (Idd) 75 100 135 75 100 135 75 100 135 75 100 135 mA Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
