Datasheet HMC383LC4 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz
Pages / Page6 / 3 — HMC383LC4. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Power …
File Format / SizePDF / 375 Kb
HMC383LC4. GaAs PHEMT MMIC MEDIUM. POWER AMPLIFIER, 12 - 30 GHz. Power Compression @ 18 GHz. Power Compression @ 30 GHz
HMC383LC4 GaAs PHEMT MMIC MEDIUM POWER AMPLIFIER, 12 - 30 GHz Power Compression @ 18 GHz Power Compression @ 30 GHz
HMC383LC4
v05.0514
20 20 T 18 18 Pout (dBm) Gain (dB) M 16 16 PAE (%) 14 14 Pout (dBm) Gain (dB) 12 12 PAE (%) 10 S - S 10 8 R 8 6 6 IE 4 4 Pout (dBm), GAIN (dB), PAE (%) Pout (dBm), GAIN (dB), PAE (%) 2 2 LIF 0 0 P -14 -12 -10 -8 -6 -4 -2 0 2 4 6 8 -16 -14 -12 -10 -8 -6 -4 -2 0 2 4 6 8 INPUT POWER (dBm) M INPUT POWER (dBm) R A
Output IP3 vs. Temperature Noise Figure vs. Temperature
E 30 13 W 12 O 11 26 ) 10 dB 9 ( ) E 22 8 R U 7 (dBm IG R & P 6 +25C IP3 18 +85C E F 5 A -40C IS O 4 +25C N E +85C 3 14 -40C 2 1 LIN 10 0 12 15 18 21 24 27 30 12 14 16 18 20 22 24 26 28 30 FREQUENCY (GHz) FREQUENCY (GHz)
Gain & Power vs. Supply Voltage @ 18 GHz Reverse Isolation vs. Temperature
19 0 -10 18 ) -20 +25C dB +85C 17 ( Bm), Psat (dBm) N -30 -40C IO T LA -40 16 O IS -50 (dB), P1dB (d 15 Gain P1dB -60 GAIN Psat 14 -70 4.5 5 5.5 12 14 16 18 20 22 24 26 28 30 Vdd Supply Voltage (Vdc) FREQUENCY (GHz) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
