Datasheet HMC8412TCPZ-EP (Analog Devices) - 3
DescriptionLow Noise Amplifier, 0.4 GHz to 11 GHz
Pages / Page10 / 3 — Enhanced Product. HMC8412TCPZ-EP. SPECIFICATIONS 0.4 GHz TO 3 GHz …
File Format / SizePDF / 310 Kb
Enhanced Product. HMC8412TCPZ-EP. SPECIFICATIONS 0.4 GHz TO 3 GHz FREQUENCY RANGE. Table 1. Parameter. Min Typ. Max Unit
Enhanced Product HMC8412TCPZ-EP SPECIFICATIONS 0.4 GHz TO 3 GHz FREQUENCY RANGE Table 1 Parameter Min Typ Max Unit
VDD = 5 V, supply current (IDQ) = 60 mA, RBIAS = 1.47 kΩ, and TA = 25°C, unless otherwise noted.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 0.4 3 GHz GAIN 13 15.5 dB Gain Variation over Temperature 0.005 dB/°C NOISE FIGURE 1.4 dB RETURN LOSS Input 14 dB Output 13 dB OUTPUT Power for 1 dB Compression (OP1dB) 15 18 dBm PSAT 20.5 dBm OIP3 32 dBm Measurement taken at output power (POUT) per tone = 0 dBm Second-Order Intercept (OIP2) 40 dBm Measurement taken at POUT per tone = 0 dBm POWER ADDED EFFICIENCY (PAE) 28 % Measured at PSAT SUPPLY IDQ 60 mA VDD 2 5 6 V
3 GHz TO 9 GHz FREQUENCY RANGE
VDD = 5 V, IDQ = 60 mA, RBIAS = 1.47 kΩ, and TA = 25°C, unless otherwise noted.
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 3 9 GHz GAIN 13 15 dB Gain Variation over Temperature 0.007 dB/°C NOISE FIGURE 1.5 dB RETURN LOSS Input 15 dB Output 16 dB OUTPUT OP1dB 15.5 18 dBm PSAT 20.5 dBm OIP3 33 dBm Measurement taken at POUT per tone = 0 dBm OIP2 41.5 dBm Measurement taken at POUT per tone = 0 dBm PAE 29 % Measured at PSAT SUPPLY IDQ 60 mA VDD 2 5 6 V Rev. 0 | Page 3 of 10 Document Outline Features Enhanced Product Features Applications Functional Block Diagram General Description Revision History Specifications 0.4 GHz to 3 GHz Frequency Range 3 GHz to 9 GHz Frequency Range 9 GHz to 11 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for HMC8412TCPZ-EP Power Derating Curves ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Outline Dimensions Ordering Guide
