Data SheetADL9006CHIPSSPECIFICATIONS 2 GHz TO 14 GHz VDD = 5 V, IDD = 55 mA, VGG2 = open, and TA = 25°C, unless otherwise noted. Table 1. ParameterSymbol Test Conditions/CommentsMin TypMax Unit FREQUENCY RANGE 2 14 GHz GAIN S21 13 15 dB Gain Variation over Temperature 0.008 dB/°C RETURN LOSS Input S11 15 dB Output S22 18 dB OUTPUT Power for 1 dB Compression P1dB 19 dBm Saturated Power PSAT 18 20 dBm Third-Order Intercept IP3 Measurement taken at output power (POUT) per tone = 0 dBm 24 dBm Second-Order Intercept IP2 Measurement taken at POUT per tone = 0 dBm 24 dBm NOISE FIGURE 2.2 dB 14 GHz TO 22 GHz VDD = 5 V, IDD = 55 mA, VGG2 = open, and TA = 25°C, unless otherwise noted. Table 2. ParameterSymbolTest Conditions/CommentsMinTypMaxUnit FREQUENCY RANGE 14 22 GHz GAIN S21 13.5 15.5 dB Gain Variation over Temperature 0.013 dB/°C RETURN LOSS Input S11 20 dB Output S22 25 dB OUTPUT Power for 1 dB Compression P1dB 17 dBm Saturated Power PSAT 15.5 18 dBm Third-Order Intercept IP3 Measurement taken at POUT per tone = 0 dBm 21 dBm Second-Order Intercept IP2 Measurement taken at POUT per tone = 0 dBm 30 dBm NOISE FIGURE 2.5 dB Rev. 0 | Page 3 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 2 GHz TO 14 GHz 14 GHz TO 22 GHz 22 GHz TO 28 GHz DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTRONIC DISCHARGE (ESD) RATINGS ESD Ratings for ADL9006CHIPS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS SMALL SIGNAL RESPONSE LARGE SIGNAL RESPONSE THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICs Handling Precautions ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
