Datasheet ADL9006CHIPS (Analog Devices) - 4
Description2 GHz to 28 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page16 / 4 — ADL9006CHIPS. Data Sheet. 22 GHz TO 28 GHz. Table 3. Parameter. Symbol. …
File Format / SizePDF / 547 Kb
ADL9006CHIPS. Data Sheet. 22 GHz TO 28 GHz. Table 3. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit. DC SPECIFICATIONS
ADL9006CHIPS Data Sheet 22 GHz TO 28 GHz Table 3 Parameter Symbol Test Conditions/Comments Min Typ Max Unit DC SPECIFICATIONS
VDD = 5 V, IDD = 55 mA, VGG2 = open, and TA = 25°C, unless otherwise noted.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 22 28 GHz GAIN S21 12.5 15 dB Gain Variation over Temperature 0.018 dB/°C RETURN LOSS Input S11 18 dB Output S22 20 dB OUTPUT Saturated Power PSAT 15 17 dBm Third-Order Intercept IP3 Measurement taken at POUT per tone = 0 dBm 16.5 dBm Second-Order Intercept IP2 Measurement taken at POUT per tone = 0 dBm 36 dBm NOISE FIGURE 4 dB
DC SPECIFICATIONS Table 4. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
TOTAL SUPPLY CURRENT IDD VDD = 5 V 55 mA POWER SUPPLY VOLTAGE VDD 4 5 7 V VGG2 VGG2 VGG2 = open (nominal condition) −2.0 +2.6 V Rev. 0 | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 2 GHz TO 14 GHz 14 GHz TO 22 GHz 22 GHz TO 28 GHz DC SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ELECTRONIC DISCHARGE (ESD) RATINGS ESD Ratings for ADL9006CHIPS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS SMALL SIGNAL RESPONSE LARGE SIGNAL RESPONSE THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICs Handling Precautions ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
