Data SheetADL7003SPECIFICATIONS 50 GHz TO 70 GHz FREQUENCY RANGE TDIE BOTTOM = 25°C; VDD = VDD1A = VDD2A = VDD3A = VDD4A = 3 V; IDQ = IDQ1A + IDQ2A + IDQ3A + IDQ4A = 120 mA, unless otherwise noted. Adjust VGG = VGG12A = VGG34A from −1.5 V to 0 V to achieve the desired IDQ. Typical VGG = −0.5 V for IDQ = 120 mA. Table 1. ParameterSymbolMinTypMaxUnitTest Conditions/Comments FREQUENCY RANGE 50 70 GHz GAIN 14 dB Gain Variation over Temperature 0.02 dB/°C NOISE FIGURE 5 dB RETURN LOSS Input S11 15 dB Output S22 20 dB OUTPUT Output Power for 1 dB Compression P1dB 12 dBm Saturated Output Power PSAT 16 dBm Output Third-Order Intercept OIP3 21 dBm Output power (POUT)/tone = 0 dBm with 1 MHz tone spacing INPUT Input Third-Order Intercept IIP3 7 dBm POUT/tone = 0 dBm with 1 MHz tone spacing SUPPLY Current IDQ 120 180 mA Adjust VGG to achieve IDQ = 120 mA typical Voltage VDD 2 3 4 V 70 GHz TO 90 GHz FREQUENCY RANGE TDIE BOTTOM = 25°C; VDD = VDD1A = VDD2A = VDD3A = VDD4A = 3 V; IDQ = IDQ1A + IDQ2A + IDQ3A + IDQ4A = 120 mA, unless otherwise noted. Adjust VGG = VGG12A = VGG34A from −1.5 V to 0 V to achieve the desired IDQ. Typical VGG = −0.5 V for IDQ = 120 mA. Table 2. ParameterSymbolMinTypMaxUnitTest Conditions/Comments FREQUENCY RANGE 70 90 GHz GAIN 13 15 dB Gain Variation over Temperature 0.02 dB/°C NOISE FIGURE 5.5 6.5 dB RETURN LOSS Input S11 15 dB Output S22 15 dB OUTPUT Output Power for 1 dB Compression P1dB 14 dBm Saturated Output Power PSAT 18 dBm Output Third-Order Intercept OIP3 21 dBm POUT/tone = 0 dBm with 1 MHz tone spacing INPUT Input Third-Order Intercept IIP3 6 dBm POUT/tone = 0 dBm with 1 MHz tone spacing SUPPLY Current IDQ 120 180 mA Adjust VGG to achieve IDQ = 120 mA typical Voltage VDD 2 3 4 V Rev. 0 | Page 3 of 18 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 50 GHz TO 70 GHz FREQUENCY RANGE 70 GHz TO 90 GHz FREQUENCY RANGE 90 GHz TO 95 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATIC TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
