Datasheet ADL7003 (Analog Devices) - 4
Description50 GHz to 95 GHz, GaAs, pHEMT, MMIC, Wideband Low Noise Amplifier
Pages / Page18 / 4 — ADL7003. Data Sheet. 90 GHz TO 95 GHz FREQUENCY RANGE. Table 3. …
File Format / SizePDF / 486 Kb
ADL7003. Data Sheet. 90 GHz TO 95 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
ADL7003 Data Sheet 90 GHz TO 95 GHz FREQUENCY RANGE Table 3 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
TDIE BOTTOM = 25°C; VDD = VDD1A = VDD2A = VDD3A = VDD4A = 3 V; IDQ = IDQ1A + IDQ2A + IDQ3A + IDQ4A = 120 mA, unless otherwise noted. Adjust VGG = VGG12A = VGG34A from −1.5 V to 0 V to achieve the desired IDQ. Typical VGG = −0.5 V for IDQ = 120 mA.
Table 3. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 90 95 GHz GAIN 11 dB Gain Variation over Temperature 0.02 dB/°C RETURN LOSS Input S11 15 dB Output S22 15 dB SUPPLY Current IDQ 120 180 mA Adjust VGG to achieve IDQ = 120 mA typical Voltage VDD 2 3 4 V Rev. 0 | Page 4 of 18 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 50 GHz TO 70 GHz FREQUENCY RANGE 70 GHz TO 90 GHz FREQUENCY RANGE 90 GHz TO 95 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATIC TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS Handling Precautions Mounting Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
