Datasheet HMC963LC4 (Analog Devices)
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz
Pages / Page6 / 1 — HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. Typical …
File Format / SizePDF / 365 Kb
HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC963LC4 Analog Devices
HMC963LC4
v02.0614
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz Typical Applications Features
This HMC963LC4 is ideal for: Low Noise Figure: 2.5 dB T • Point-to-Point Radios High Gain: 22 dB M • Point-to-Multi-Point Radios P1dB Output Power: 10 dBm • Military & Space Single Supply Voltage: +3.5V @ 45mA E - S • Test Instrumentation Output IP3: +18 dBm IS 50 Ohm matched Input/Output O 24 Lead 4x4 mm SMT Package: 16mm² W N
O The HMC963LC4 is a self-biased GaAs MMIC Low Noise Amplifier housed in a leadless 4x4 mm ceramic S - L surface mount package. The amplifier operates R between 6 and 26.5 GHz, providing 20 dB of small IE signal gain, 2.5 dB noise figure, and output IP3 of +18 dBm, while requiring only 45 mA from a +3.5 V LIF supply. The P1dB output power of +10 dBm enables P the LNA to function as a LO driver for balanced, I/Q M or image reject mixers. The HMC963LC4 also fe- A atures I/Os that are DC blocked and internal y mat- ched to 50 Ohms, making it ideal for high capacity microwave radios and VSAT applications.
Electrical Specifications, T = +25° C, Vdd1 = Vdd2 = +3.5V, Idd = 45 mA A
Parameter Min. Typ. Max. Units Frequency Range 6 - 26.5 GHz Gain 16.5 22 dB Gain Variation over Temperature 0.03 dB / °C Noise Figure [1] 2.5 3.5 dB Input Return Loss 10 dB Output Return Loss 10 dB Output Power for 1 dB Compression 7 10 dBm Saturated Output Power (Psat) 12 dBm Output Third Order Intercept (IP3) 18 dBm Supply Current (Idd) 45 65 mA (Vdd = 3.5V, Vgg1 = Vgg2 = Open) [1] Board loss subtracted out. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
1
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
