Datasheet HMC963LC4 (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz
Pages / Page6 / 4 — HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. Current …
File Format / SizePDF / 365 Kb
HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. Current vs. Input Power @ 16 GHz. Absolute Maximum Ratings
HMC963LC4 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz Current vs Input Power @ 16 GHz Absolute Maximum Ratings
HMC963LC4
v02.0614
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz Current vs. Input Power @ 16 GHz Absolute Maximum Ratings
64 Drain Bias Voltage +4V RF Input Power 0 dBm 60 T Channel Temperature 150 °C 56 M Continuous Pdiss (T = 85 °C) 0.52 W (derate 8 mW/°C above 85 °C) (mA) 52 Thermal Resistance Idd 125 °C/W (Channel to ground paddle) 48 E - S Storage Temperature -65 to +150 °C IS 44 Operating Temperature -40 to +85 °C O ESD Sensitivity (HBM) Class 0 <150 V 40 -18 -15 -12 -9 -6 -3 0 INPUT POWER (dBm) W N ELECTROSTATIC SENSITIVE DEVICE O OBSERVE HANDLING PRECAUTIONS
Outline Drawing
S - L R IE LIF P M A NOTES: 1. PACKAGE BODY MATERIAL: ALUMINA. 2. LEAD AND GROUND PADDLE PLATING: GOLD FLASH OVER NICKEL. 3. DIMENSIONS ARE IN INCHES (MILLIMETERS). 4. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. 5. PACKAGE WARP SHALL NOT EXCEED 0.05MM DATUM – C – 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC963LC4 Alumina, White Gold over Nickel MSL3 [1] H963 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
