Datasheet HMC963LC4 (Analog Devices) - 3
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz
Pages / Page6 / 3 — HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. P1dB vs. …
File Format / SizePDF / 365 Kb
HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC963LC4 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz P1dB vs Temperature Psat vs Temperature
HMC963LC4
v02.0614
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz P1dB vs. Temperature Psat vs. Temperature
15 17 T +25C +25C M 13 +85C 15 +85C -40C -40C 11 13 (dBm) (dBm) E - S 9 11 P1dB P1dB IS O 7 9 5 7 W N 6 8 10 12 14 16 18 20 22 24 26 28 6 8 10 12 14 16 18 20 22 24 26 28 FREQUENCY (GHz) FREQUENCY (GHz) O S - L
Reverse Isolation vs. Temperature Power Compression @ 8 GHz
R 0 24 IE -10 20 (%) -20 PAE 16 LIF +25C +85C P (dB N -30 -40C (dB), 12 IO M T LA -40 GAIN 8 A O IS -50 4 (dBm), Pout Gain -60 0 PAE Pout -70 -4 6 8 10 12 14 16 18 20 22 24 26 28 -18 -15 -12 -9 -6 -3 0 FREQUENCY (GHz) INPUT POWER (dBm)
Power Compression @ 16 GHz Power Compression @ 24 GHz
24 24 20 (%) 20 (%) PAE 16 PAE 16 (dB), 12 (dB), 12 GAIN 8 GAIN 8 4 (dBm), Pout 4 (dBm), Pout Gain Gain 0 PAE Pout 0 PAE Pout -4 -4 -18 -15 -12 -9 -6 -3 0 -18 -15 -12 -9 -6 -3 0 INPUT POWER (dBm) INPUT POWER (dBm) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
