Datasheet HMC963LC4 (Analog Devices) - 6
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz
Pages / Page6 / 6 — HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. Evaluation …
File Format / SizePDF / 365 Kb
HMC963LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 6 - 26.5 GHz. Evaluation PCB
HMC963LC4 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 6 - 26.5 GHz Evaluation PCB
HMC963LC4
v02.0614
T M E - S IS O W N O S - L R IE LIF P M A
List of Material for Evaluation PCB EVAL01-HMC963LC4 [1]
Item Description The circuit board used in this application should J1, J2 2.92 mm Connectors use RF circuit design techniques. Signal lines should have 50 Ohm impedance while the pack- J3 - J8 DC Pin age ground leads and exposed paddle should be C1 - C3 100 pF Capacitor, 0402 Pkg. connected directly to the ground plane similar to C4 - C6 1000 pF Capacitor, 0603 Pkg. that shown. A sufficient number of via holes should C8 - C10 2.2 µF Capacitor, Tantalum be used to connect the top and bottom ground U1 HMC963LC4 Amplifier planes. The evaluation board should be mounted PCB [2] 108535 Evaluation PCB to an appropriate heat sink. The evaluation circuit [1] Reference this number when ordering complete evaluation PCB board shown is available from Hittite upon request. [2] Circuit Board Material: Rogers 4350 or Arlon 25FR Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
