Datasheet HMC599ST89, 599ST89E (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC LNA, 75 Ohm 50 - 1000 MHz
Pages / Page8 / 5 — HMC599ST89 / 599ST89E. GaAs pHEMT MMIC LNA, 75 Ohm. 50 - 1000 MHz. Gain …
File Format / SizePDF / 525 Kb
HMC599ST89 / 599ST89E. GaAs pHEMT MMIC LNA, 75 Ohm. 50 - 1000 MHz. Gain vs. Supply Voltage. Noise Figure vs. Supply Voltage
HMC599ST89 / 599ST89E GaAs pHEMT MMIC LNA, 75 Ohm 50 - 1000 MHz Gain vs Supply Voltage Noise Figure vs Supply Voltage
v02.0311
7
Gain vs. Supply Voltage Noise Figure vs. Supply Voltage
T 17 10 9 m 16 8 s 15 ) 2.7V 7 3.0V (dB ) 3.3V 14 E R 6 4.5V 5.0V U e - (dB 13 5.5V IN IG 2.7V 5 A 3.0V F E is G 12 3.3V 4 IS 4.5V O 5.0V N 3 o 11 5.5V 2 10 1 9 0 w N 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 0 100 200 300 400 500 600 700 800 900 1000 FREQUENCY (GHz) FREQUENCY (MHz) lo s -
IP3 vs. Supply Voltage
r 44 ie 40 lif 36 p ) 32 m (dBm A 28 IP3 24 20 2.7V 4.5V 3.0V 5.0V 3.3V 5.5V 16 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 FREQUENCY (GHz)
P1dB vs. Supply Voltage Psat vs. Supply Voltage
24 24 20 20 16 16 (dBm) (dBm) 12 12 P1dB P1dB 8 8 2.7V 4.5V 2.7V 4.5V 4 3.0V 5.0V 4 3.0V 5.0V 3.3V 5.5V 3.3V 5.5V 0 0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 FREQUENCY (GHz) FREQUENCY (GHz) Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
7 - 5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
