Datasheet HMC566 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 29 - 36 GHz
Pages / Page6 / 4 — HMC566. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 29 - 36 GHz. Absolute …
File Format / SizePDF / 337 Kb
HMC566. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 29 - 36 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC566 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 29 - 36 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC566
v00.0306
1
Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain Bias Voltage (Vdd1, 2, 3, 4) +3.5 Vdc Vdd (Vdc) Idd (mA) RF Input Power (RFIN)(Vdd = +3.0 Vdc) +5 dBm +2.5 77 IP +3.0 80 Channel Temperature 175 °C H +3.5 83 Continuous Pdiss (T= 85 °C) 0.82 W C (derate 9.6 mW/°C above 85 °C) Note: Amplifi er will operate over full voltage ranges shown - above. Thermal Resistance 104.2 °C/W (channel to die bottom) RS Storage Temperature -65 to +150 °C IE Operating Temperature -55 to +85 °C ELECTROSTATIC SENSITIVE DEVICE IF OBSERVE HANDLING PRECAUTIONS L P M A E
Outline Drawing
IS O N W O L NOTES: 1. ALL DIMENSIONS ARE IN INCHES [MM]
Die Packaging Information
[1] 2. DIE THICKNESS IS .004” Standard Alternate 3. TYPICAL BOND IS .004” SQUARE 4. BACKSIDE METALLIZATION: GOLD GP-2 (Gel Pack) [2] 5. BOND PAD METALLIZATION: GOLD [1] Refer to the “Packaging Information” section for die 6. BACKSIDE METAL IS GROUND. 7. CONNECTION NOT REQUIRED FOR UNLABELED BOND PADS. packaging dimensions. [2] For alternate packaging information contact Hittite Microwave Corporation. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com
1 - 93
Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
