Datasheet HMC566 (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 29 - 36 GHz
Pages / Page6 / 5 — HMC566. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 29 - 36 GHz. Pad …
File Format / SizePDF / 337 Kb
HMC566. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 29 - 36 GHz. Pad Descriptions. Assembly Diagram. 1 - 94
HMC566 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 29 - 36 GHz Pad Descriptions Assembly Diagram 1 - 94
HMC566
v00.0306
1
Pad Descriptions
Pad Number Function Description Interface Schematic IP H This pad is AC coupled and matched to 1 IN 50 Ohms from 29 - 36 GHz. C - Power Supply Voltage for the amplifi er. External bypass 2, 3, 4, 5 Vdd1, 2, 3, 4 capacitors of 100 pF and 0.1 μF are required. RS IE This pad is AC coupled and matched to IF 6 OUT 50 Ohms from 29 - 36 GHz. L P Die Bottom GND Die Bottom must be connected to RF/DC ground. M A E IS
Assembly Diagram
O N W O L Information furnish F ed obr pri y Anal ce, de og Device li s vie s r beyli, a eve nd to pla d to be accura ce o te and rder reliabl s e , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
1 - 94
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon - e 25 : 7 0 81--3 32 3 9 4 - 3 F 70 ax 0 • O : 978 rder on -li25 n 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.h A it p tpite.co licatio m n Support: Phone: 1-800-ANALOG-D
