Datasheet HMC7229LS6 (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, 1 W, Power Amplifier with Power Detector, 37 GHz to 40 GHz
Pages / Page15 / 3 — Data Sheet. HMC7229LS6. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table …
RevisionE
File Format / SizePDF / 328 Kb
Data Sheet. HMC7229LS6. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
Data Sheet HMC7229LS6 SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
TA = 25°C, VDD1 to VDD4 (VDDx) = 6 V, IDD = 1200 mA (adjust VGG1/VGG2, VGGx, between −2 V to 0 V to achieve an IDD = 1200 mA typical), unless otherwise stated.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 37 40 GHz GAIN 21 24 dB Gain Variation over Temperature 0.058 dB/°C RETURN LOSS Input 16 dB Output 14 dB OUTPUT POWER For P1dB Compression 28.5 31.5 dBm Saturated (PSAT) With 18% PAE at 39 GHz 32 dBm OUTPUT THIRD-ORDER INTERCEPT (IP3) Measurement taken at POUT/tone = 20 dBm 40 dBm TOTAL SUPPLY CURRENT (IDD)1 VDD = 5 V, VDD = 5.5 V, and VDD = 6 V 1200 mA 1 Adjust VGGx to achieve IDD = 1200 mA. Rev. E | Page 3 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCE During Power-Up During Power-Down EVALUATION PRINTED CIRCUIT BOARD (PCB) TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
