Datasheet HMC7229LS6 (Analog Devices) - 4
DescriptionGaAs, pHEMT, MMIC, 1 W, Power Amplifier with Power Detector, 37 GHz to 40 GHz
Pages / Page15 / 4 — HMC7229LS6. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter …
RevisionE
File Format / SizePDF / 328 Kb
HMC7229LS6. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
HMC7229LS6 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
HMC7229LS6 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Drain Bias Voltage (VDDx) 7 V or any other conditions above those indicated in the Minimum Gate Voltage (VGG1, VGG2) −3 V operational section of this specification is not implied. RF Input Power (RFIN) 21 dBm Operation beyond the maximum operating conditions for Channel Temperature 175°C extended periods may affect product reliability. Continuous Power Dissipation, PDISS (T = 9.0 W 85°C, Derates 95 mW/°C Above 85°C) Thermal Resistance (Channel to Ground 10°C/W
ESD CAUTION
Paddle) Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +85°C ESD Sensitivity (Human Body Model) Class 0, passed 150 V Rev. E | Page 4 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION RECOMMENDED BIAS SEQUENCE During Power-Up During Power-Down EVALUATION PRINTED CIRCUIT BOARD (PCB) TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
