HMC454ST89 / 454ST89E v05.0710 InGaP HBT ½ WATT HIGH IP3AMPLIFIER, 0.4 - 2.5 GHzPin Descriptions Pin Number Function Description Interface Schematic This pin is AC coupled. 1 RFIN Off chip matching components are required. See Application Circuit herein. RF output and DC Bias input for the output amplifi er stage. 9 3 RFOUT Off chip matching components are required. See Application Circuit herein. T These pins & package bottom must be connected to 2,4 GND RF/DC ground. R - SM E W O 900 MHz Application Circuit, Compact Layout This circuit was used to specify the performance for 894-960 MHz operation. This circuit will satisfy many applications from 700 to 1200 MHz. Contact the HMC Applications Group for assistance in optimizing performance for your R & P application. A E IN S - L R IE IF L P M A TL1 Recommended Component Values Impedance 50 Ohm L1, L2 1 nH Physical Length 0.050” L3 36 nH Electrical Length 2.5° R1 5.1 Ohms PCB Material: 10 mil Rogers 4350, C1 8 pF Er = 3.48 C2 22 pF C3 2.7 pF C4, C6 100 pF C5 2.2 μF Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m 9 - 196 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
