HMC454ST89 / 454ST89E v05.0710 InGaP HBT ½ WATT HIGH IP3AMPLIFIER, 0.4 - 2.5 GHz900 MHz Evaluation PCB 9 T R - SM E W O R & P A E IN List of Materials for Evaluation PCB 107755 [1] S - L The circuit board used in this application should use R Item Description RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA Connector IE have 50 Ohm impedance while the package ground J3 -J4 DC Pins IF leads and exposed paddle should be connected C1 8 pF Capacitor, 0402 Pkg. L directly to the ground plane similar to that shown. C2 22 pF Capacitor, 0402 Pkg. P A sufficient number of via holes should be used to C3 2.7 pF Capacitor, 0402 Pkg. M connect the top and bottom ground planes. The C4, C6 100 pF Capacitor, 0402 Pkg. A evaluation board should be mounted to an appro- C5 2.2 μF Capacitor, Tantalum priate heat sink. The evaluation circuit board shown L1, L2 1 nH Inductor, 0402 Pkg. is available from Hittite upon request. L3 36 nH Inductor, 0402 Pkg. R1 5.1 Ohms HMC454ST89 / HMC454ST89E U1 Linear Amp PCB [2] 107753 Evaluation PCB, 10 mils [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Rogers 4350, Er = 3.48 Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com 9 - 197 Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
