Datasheet HMC454ST89, 454ST89E (Analog Devices) - 9
DescriptionInGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz
Pages / Page12 / 9 — HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 …
File Format / SizePDF / 629 Kb
HMC454ST89 / 454ST89E. InGaP HBT ½ WATT HIGH IP3. AMPLIFIER, 0.4 - 2.5 GHz. 1960 & 2140 MHz Application Circuit. 9 - 198
HMC454ST89 / 454ST89E InGaP HBT ½ WATT HIGH IP3 AMPLIFIER, 0.4 - 2.5 GHz 1960 & 2140 MHz Application Circuit 9 - 198
v05.0710
This circuit was used to specify the performance for 1800-2000 and 2000-2200 MHz operation. This circuit will satisfy many applications from 1700 to 2500 MHz. Contact the HMC Applications Group for assistance in optimizing performance for your application. 9 T R - SM E W O R & P A TL1 TL2 T3 TL4 Recommended Component Values E Impedance 50 Ohm 50 Ohm 50 Ohm 50 Ohm L1 8.2 nH Physical Length 0.32” 0.10” 0.07” 0.17” C1 1 pF IN Electrical Length 34° 11° 8° 18.5° C2 1.2 pF PCB Material: 10 mil Rogers 4350, Er = 3.48 C3 3 pF S - L C4 100 pF R C5 2.2 μF IE IF L P M A Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
9 - 198
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
