Datasheet AEM00300 (E-peas) - 10
Manufacturer | E-peas |
Description | Highly Versatile Buck-Boost Ambient Energy Manager Battery Charger with Source Voltage Level Configuration |
Pages / Page | 26 / 10 — DATASHEET. AEM00300. 5. Recommended Operation Conditions |
File Format / Size | PDF / 768 Kb |
link to page 18
DATASHEET AEM00300 5. Recommended Operation Conditions
Symbol Parameter Min Typ Max Unit External Components LDCDC Inductor of the DCDC converter 10 µH CSRC Capacitor decoupling the SRC terminal 15 µF CINT Capacitor decoupling the VINT terminal 10 µF CSTO Optional - Capacitor on STO if no storage element is connected (see Section 8.6.1) 100 µF STO_OVCH Configuration of VOVCH in custom mode STO_OVDIS Configuration of VOVDIS in custom mode 1 Section 0.9 100 MΩ STO_RDY Configuration of VCHRDY in custom mode Symbol Logic Level Low High Logic input pins SRC_LVL_CFG[5:0] Configuration pins for the SRC voltage level GND VINT STO_CFG[3:0] Configuration pins for the STO voltage GND VINT EN_STO_FT Configuration pin for the control er GND VINT EN_STO_CH Configuration pin for the control er GND VINT EN_HP Configuration pin for the control er GND VINT Table 7: Recommended Operation Conditions DS_AEM00300_Rev1.0 Copyright © 2022 e-peas SA 11 Document Outline Table of Contents List of Tables 1. Introduction 2. Absolute Maximum Ratings 3. Thermal Resistance 4. Typical Electrical Characteristics at 25 °C 5. Recommended Operation Conditions 6. Functional Block Diagram 7. Theory of Operation 7.1. DCDC Converter 7.2. Reset and Wake Up States 7.3. Supply State 7.4. Source Voltage Regulation 7.5. Balancing for Dual-Cell Supercapacitor 8. System Configuration 8.1. High Power / Low Power Mode 8.2. Storage Element Configuration 8.3. Custom Mode Configuration 8.4. Disable Storage Element Charging 8.5. Source Level Configuration 8.6. External Components 8.6.1. Storage element information 8.6.2. External inductor information 8.6.3. External capacitors information CSRC CINT 9. Typical Application Circuits 9.1. Example Circuit 1 9.2. Example Circuit 2 9.3. Circuit Behaviour 9.4. DCDC Conversion Efficiency From SRC to STO in Low Power Mode 9.4. DCDC Conversion Efficiency From SRC to STO in Low Power Mode 9.5. DCDC Conversion Efficiency From SRC to STO in High Power Mode 10. Schematic 11. Layout 12. Package Information 12.1. Plastic Quad Flatpack No-Lead (QFN 28-pin 4x4mm) 12.2. Board Layout 13. Revision History
