Datasheet ADG1634-KGD (Analog Devices) - 7
Description4.5 Ω RON, Quad SPDT ±5 V, +12 V, +5 V, and +3.3 V Switch
Pages / Page13 / 7 — Data Sheet. ADG1634-KGD. −40°C to −40°C to. Parameter. 25°C +85°C. …
File Format / SizePDF / 368 Kb
Data Sheet. ADG1634-KGD. −40°C to −40°C to. Parameter. 25°C +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG1634-KGD −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
link to page 11 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12
tD 81 ns typ RL = 300 Ω, CL = 35 pF 48 ns min VS1 = VS2 = 1.5 V, see Figure 7 Charge Injection −10 pC typ VS = 1.5 V, RS = 0 Ω, CL = 1 nF, see Figure 9 Off Isolation −64 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz, see Figure 10 Channel-to-Channel Crosstalk −64 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz, see Figure 12 THD + N 0.6 % typ RL = 110 Ω, f = 20 Hz to 20 kHz, VS = 2 V p-p, see Figure 13 −3 dB Bandwidth 117 MHz typ RL = 50 Ω, CL = 5 pF, see Figure 11 CS (Off) 22 pF typ VS = 1.5 V, f = 1 MHz CD (Off) 39 pF typ VS = 1.5 V, f = 1 MHz CD, CS (On) 64 pF typ VS = 1.5 V, f = 1 MHz POWER REQUIREMENTS VDD = 3.6 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max VDD 3.3/16 V min/max 1 Guaranteed by design but not subject to production test.
CONTINUOUS CURRENT PER CHANNEL, S OR D Table 5. Parameter 25°C 85°C 125°C Unit
CONTINUOUS CURRENT, S OR D VDD = +5 V, VSS = −5 V θJA = 95°C/W 112 77 52 mA max θJA = 30.4°C/W 220 136 73 mA max VDD = 12 V, VSS = 0 V θJA = 95°C/W 119 80 52 mA max θJA = 30.4°C/W 234 140 73 mA max VDD = 5 V, VSS = 0 V θJA = 95°C/W 87 63 42 mA max θJA = 30.4°C/W 171 112 66 mA max VDD = 3.3 V, VSS = 0 V θJA = 95°C/W 70 52 35 mA max θJA = 30.4°C/W 140 94 59 mA max Rev. 0 | Page 7 of 13 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V DUAL SUPPLY 12 V SINGLE SUPPLY 5 V SINGLE SUPPLY 3.3 V SINGLE SUPPLY CONTINUOUS CURRENT PER CHANNEL, S OR D ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TEST CIRCUITS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
