Datasheet ADG1436-EP (Analog Devices) - 4
Description1.5 Ω On Resistance, ±15 V/12 V/±5 V, iCMOS , Dual SPDT Switch
Pages / Page10 / 4 — ADG1436-EP. Enhanced Product. 12 V SINGLE SUPPLY. Table 2. Parameter. …
File Format / SizePDF / 253 Kb
ADG1436-EP. Enhanced Product. 12 V SINGLE SUPPLY. Table 2. Parameter. 25°C. −55°C to +125°C. Unit. Test Conditions/Comments
ADG1436-EP Enhanced Product 12 V SINGLE SUPPLY Table 2 Parameter 25°C −55°C to +125°C Unit Test Conditions/Comments
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. Parameter 25°C −55°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance, RON 2.8 Ω typ VS = 0 V to 10 V, IS = −10 mA 3.5 4.8 Ω max VDD = 10.8 V, VSS = 0 V On-Resistance Match Between Channels, ∆RON 0.13 Ω typ VS = 0 V to 10 V, IS = −10 mA 0.21 0.25 Ω max On-Resistance Flatness, RFLAT(ON) 0.6 Ω typ VS = 0 V to 10 V, IS = −10 mA 1.1 1.3 Ω max Continuous Current Per Channel1 240 100 mA max VDD = 10.8 V, VSS = 0 V LEAKAGE CURRENTS VDD = 13.2 V, VSS = 0 V Source Off Leakage, IS (Off) ±0.04 nA typ VS = 1 V/10 V, VD = 10 V/1 V ±0.55 ±12.5 nA max Drain Off Leakage, ID (Off) ±0.04 nA typ VS = 1 V/10 V, VD = 10 V/1 V ±0.55 ±12.5 nA max Channel On Leakage, ID, IS (On) ±0.1 nA typ VS = VD = 1 V or 10 V ±1 ±35 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 µA typ VIN = VGND or VDD ±0.1 µA max Digital Input Capacitance, CIN 3.5 pF typ DYNAMIC CHARACTERISTICS1 Transition Time, tTRANSITION 200 ns typ RL = 300 Ω, CL = 35 pF 270 350 ns max VS = 8 V Break-Before-Make Time Delay, tBBM 70 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 8 V Charge Injection 30 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF Off Isolation −80 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz Channel-to-Channel Crosstalk −80 dB typ RL = 50 Ω, CL = 5 pF, f = 100 kHz −3 dB Bandwidth 78 MHz typ RL = 50 Ω, CL = 5 pF Insertion Loss −0.3 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz CS (Off) 40 pF typ f = 1 MHz, VS = 6 V CD (Off) 80 pF typ f = 1 MHz, VS = 6 V CD, CS (On) 140 pF typ f = 1 MHz, VS = 6 V POWER REQUIREMENTS VDD = 13.2 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max IDD 170 µA typ Digital inputs = 5 V 285 µA max VDD 5/16.5 V min/max GND = 0 V, VSS = 0 V 1 Guaranteed by design, not subject to production test. Rev. 0 | Page 4 of 10 Document Outline Features Applications Enhanced Product Features Functional Block Diagram General Description Revision History Specifications 15 V Dual Supply 12 V Single Supply 5 V Dual Supply Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Truth Table For Switches Typical Performance Characteristics Outline Dimensions Ordering Guide
