Datasheet ADG1236 (Analog Devices) - 5
DescriptionLow Capacitance, Low Charge Injection, ±15 V/12 V iCMOS, Dual SPDT Switch
Pages / Page16 / 5 — Data Sheet. ADG1236. SINGLE SUPPLY. Table 2. Y Version1. Parameters. …
File Format / SizePDF / 351 Kb
Data Sheet. ADG1236. SINGLE SUPPLY. Table 2. Y Version1. Parameters. 25°C. −40°C to +85°C −40°C to +125°C. Unit. Test Conditions/Comments
Data Sheet ADG1236 SINGLE SUPPLY Table 2 Y Version1 Parameters 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 13 link to page 13 link to page 13
VDD = 12 V ± 10%, VSS = 0 V, GND = 0 V, unless otherwise noted.
Table 2. Y Version1 Parameters 25°C −40°C to +85°C −40°C to +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 300 Ω typ VS = 0 V to 10 V, IS = −1 mA; Figure 20 475 567 625 Ω max VDD = 10.8 V, VSS = 0 V On Resistance Match Between 4.5 Ω typ VS = 0 V to 10 V, IS = −1 mA Channels (∆RON) 16 26 27 Ω max On Resistance Flatness (RFLAT(ON)) 60 Ω typ VS = 3 V, 6 V, 9 V, IS = −1 mA LEAKAGE CURRENTS VDD = 13.2 V Source Off Leakage, IS (Off) ±0.02 nA typ VS = 1 V/10 V, VD = 10 V/1 V; Figure 21 ±0.1 ±0.6 ±1 nA max Drain Off Leakage, ID (Off) ±0.02 nA typ VS = 1 V/10 V, VD = 10 V/1 V; Figure 21 ±0.1 ±0.6 ±1 nA max Channel On Leakage, ID, IS (On) ±0.02 nA typ VS = VD = 1 V or 10 V, Figure 22 ±0.2 ±0.6 ±1 nA max DIGITAL INPUTS Input High Voltage, VINH 2.0 V min Input Low Voltage, VINL 0.8 V max Input Current, IINL or IINH 0.001 µA typ VIN = VINL or VINH ±0.1 µA max Digital Input Capacitance, CIN 3 pF typ DYNAMIC CHARACTERISTICS2 Transition Time, tTRANS BOFF AON 105 ns typ RL = 300 Ω, CL = 35 pF 140 175 ns max VS = 8 V; Figure 23 Transition Time, tTRANS AOFF BON 155 ns typ RL = 300 Ω, CL = 35 pF 190 255 ns max VS = 8 V; Figure 23 Break-Before-Make Time Delay, tD 50 ns typ RL = 300 Ω, CL = 35 pF 10 ns min VS1 = VS2 = 8 V; Figure 24 Charge Injection −0.8 pC typ VS = 6 V, RS = 0 Ω, CL = 1 nF; Figure 25 Off Isolation 75 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 26; Channel-to-Channel Crosstalk 85 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; Figure 27 −3 dB Bandwidth 800 MHz typ RL = 50 Ω, CL = 5 pF; Figure 28 CS (Off) 1.6 pF typ f = 1 MHz; VS = 6 V 1.9 pF max f = 1 MHz; VS = 6 V CD, CS (On) 4 pF typ f = 1 MHz; VS = 6 V 4.9 pF max f = 1 MHz; VS = 6 V POWER REQUIREMENTS VDD = 13.2 V IDD 0.001 µA typ Digital inputs = 0 V or VDD 1.0 µA max IDD 170 µA typ Digital inputs = 5 V 230 µA max 1 Temperature range for Y version is −40°C to +125°C. 2 Guaranteed by design; not subject to production test. Rev. A | Page 5 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION TRUTH TABLE FOR SWITCHES PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
